I am going to make a regulator circuit with 3.3V 2A output using MAX1655 Step down controller.
I am going to use a solar panel with following specs for input: Max output voltage: 8.4V
Nominal voltage:6V
Current at MPP: 0.62A
As per the datasheet for MAX1655(at page 11) i have to use dual N-Channel Mosfet IRF7303 for the circuit diagram(3.3V /2A Output) at page 10 of the datasheet.
Questions: 1)Can i use two units of IRFZ44N instead of IRF7303 in the circuit(3.3V/2 A Output)? ( IRF7303 is unavailable at local shops near me and the Mosfet they have with closest specs to IRF7303 is IRFZ44N )
2)Would the MAX1655 Controller be damaged by the use of IRFZ44N? Would i face any other problems?
