I have a HSMC Interface which has 32 Bit width data word changing at 100 MHz. How is the correct maximum data throughput calculated?
Is it just dataword_length / clock_period [bits/ns]. And then I will convert to MByte/s. This is a question on the raw data speed (signalrate). There are no protocol headers involved here.
    \$\begingroup\$ well. seriously, take a wild guess. \$\endgroup\$ – Marcus Müller Jul 11 '18 at 14:59
    \$\begingroup\$ Specify which kind of HSMC are you using! Are you sure you have 32Bit. The standard connector provides 16bit lvds. \$\endgroup\$ – abu_bua Jul 11 '18 at 15:11
  • \$\begingroup\$ It is 32 Bit HSMC Connector at an FPGA. Thank you \$\endgroup\$ – hendrik2k1 Jul 12 '18 at 8:15
Clocked 32bits wide clocked at 100MHz would be:
100E6 DWords per second.
400E6 Bytes per second.
3200E6 Bits per second.
