I managed to route an entire complex board with eagle, or so I thought. At first it worked. Then I began adding large fills (ground planes and VCC planes) in order to minimize impedance.
I now added extra circuitry to my board and manually routed those parts in place.
I now run the autorouter one more time and watched the progress. In all optimize stages, it showed 100% which made me think everything went perfectly. Then after it was done, it reverted back to 98% (1 unrouted wire left).
I turned off the copper layer on the board as well as the grid and I couldn't see where this unrouted wire is and I even zoomed in.
Is this a bug that exists in eagle when I define multiple planes close to each other? or is there some other trick I can use so eagle can stay at 100% instead of reverting to 98%?
