So I can define a package with a generic - in this case, the package takes a size as a generic and defines a vector type of that size:
library ieee;
use ieee.std_logic_1164.all;
package vector_package is
    generic (
    subtype vector_t is std_logic_vector (size - 1 downto 0);
end package;
Now I can instantiate that package within an architecture to create a signal of that vector type:
entity foo is
end entity;
architecture rtl of foo is
    package vp_4 is new work.vector_package generic map (size => 4);
    signal vector : vp_4.vector_t;
begin
end architecture;
But what I want is to use the vector type for a port signal. I would have expected to be able to do something like this, but it does not appear to be valid VHDL 2008:
entity bar is
    port (
        signal vector : out vp_4.vector_t);
end entity;
This is rejected by ModelSim 10.2c with the message (vcom-1136) Unknown identifier "vp_4". in the line containing signal vector : ....
Is there a way to use the type from the package for a port signal? I am aware of unconstrained types as an alternative, but they do not fit my requirements in the actual use case.
  • \$\begingroup\$ An expanded name - signal vector : out work.vp_4.vector_t or a use clause - use work.all; making vp4 visible in the entity declaration. \$\endgroup\$
    – user8352
    Commented Jul 12, 2018 at 13:08
    \$\begingroup\$ See IEEE Std 1076-2008 13.1 Design units. A package instantiation declaration is a primary unit and doesn't share the same root declarative region with the entity declaration (12.1 Declarative region, "In addition to the preceding declarative regions, there is a root declarative region, not associated with a portion of the text of the description, but encompassing any given primary unit"). You've instantiated the package in the same resource library as the following entity declaration. \$\endgroup\$
    – user8352
    Commented Jul 12, 2018 at 13:44
  • \$\begingroup\$ @user8352 Indeed, work.vp_4.vector_t works. Would you convert your comment to an answer, so I can accept it? \$\endgroup\$
    – Martin
    Commented Jul 13, 2018 at 9:19
Credit for the answer goes to user8352 who provided the solution and some background. The vp_4 package is found in the work library and the following will work:
entity bar is
    port (
        signal vector : out work.vp_4.vector_t);
end entity;
