I've got an error message when Xilinx ISE mapping processing. and I'm trying to resolve this ERROR:Pack:1107 problem. But I can't understand this, what does it mean.
my target board is Spartan6lx16 2c. and external clock is assigned as 50Mhz.
ERROR:Pack:1107 - Pack was unable to combine the symbols listed below into a
   single IOBS component because the site type selected is not compatible.
   Further explanation:
   The component type is determined by the types of logic and the properties and
   configuration of the logic it contains. In this case an IO component of type
   IOBS was chosen because the IO contains symbols and/or properties consistent
   with differential slave usage. Please double check that the types of logic
   elements and all of their relevant properties and configuration options are
   compatible with the physical site type of the constraint.
   Summary:
   Symbols involved:
    PAD symbol "TMDSn_clock" (Pad Signal = TMDSn_clock)
    SlaveBuffer symbol "OBUFDS_clock/SLAVEBUF.DIFFOUT" (Output Signal =
   TMDSn_clock)
   Component type involved: IOBS
   Site Location involved: B14
   Site Type involved: IOBM
What am I supposed to do to resolve this mapping error?
This is the whole code.
// (c) fpga4fun.com & KNJN LLC 2013
module HDMI_test(
    input wire pixclk,  // 25MHz
    output wire [2:0] TMDSp,
    output wire [2:0] TMDSn,
    output wire TMDSp_clock,
    output wire TMDSn_clock
reg [9:0] CounterX, CounterY;
reg hSync, vSync, DrawArea;
always @(posedge pixclk) DrawArea <= (CounterX<640) && (CounterY<480);
always @(posedge pixclk) CounterX <= (CounterX==799) ? 0 : CounterX+1;
always @(posedge pixclk) if(CounterX==799) CounterY <= (CounterY==524) ? 0 : CounterY+1;
always @(posedge pixclk) hSync <= (CounterX>=656) && (CounterX<752);
always @(posedge pixclk) vSync <= (CounterY>=490) && (CounterY<492);
wire [7:0] W = {8{CounterX[7:0]==CounterY[7:0]}};
wire [7:0] A = {8{CounterX[7:5]==3'h2 && CounterY[7:5]==3'h2}};
reg [7:0] red, green, blue;
always @(posedge pixclk) red <= ({CounterX[5:0] & {6{CounterY[4:3]==~CounterX[4:3]}}, 2'b00} | W) & ~A;
always @(posedge pixclk) green <= (CounterX[7:0] & {8{CounterY[6]}} | W) & ~A;
always @(posedge pixclk) blue <= CounterY[7:0] | W | A;
wire [9:0] TMDS_red, TMDS_green, TMDS_blue;
TMDS_encoder encode_R(.clk(pixclk), .VD(red  ), .CD(2'b00)        , .VDE(DrawArea), .TMDS(TMDS_red));
TMDS_encoder encode_G(.clk(pixclk), .VD(green), .CD(2'b00)        , .VDE(DrawArea), .TMDS(TMDS_green));
TMDS_encoder encode_B(.clk(pixclk), .VD(blue ), .CD({vSync,hSync}), .VDE(DrawArea), .TMDS(TMDS_blue));
wire clk_TMDS, DCM_TMDS_CLKFX;  // 25MHz x 10 = 250MHz
DCM_SP #(.CLKFX_MULTIPLY(5)) DCM_TMDS_inst(.CLKIN(pixclk), .CLKFX(DCM_TMDS_CLKFX), .RST(1'b0));
BUFG BUFG_TMDSp(.I(DCM_TMDS_CLKFX), .O(clk_TMDS));
reg [3:0] TMDS_mod10=0;  // modulus 10 counter
reg [9:0] TMDS_shift_red=0, TMDS_shift_green=0, TMDS_shift_blue=0;
reg TMDS_shift_load=0;
always @(posedge clk_TMDS) TMDS_shift_load <= (TMDS_mod10==4'd9);
begin
    TMDS_shift_red   <= TMDS_shift_load ? TMDS_red   : TMDS_shift_red  [9:1];
    TMDS_shift_green <= TMDS_shift_load ? TMDS_green : TMDS_shift_green[9:1];
    TMDS_shift_blue  <= TMDS_shift_load ? TMDS_blue  : TMDS_shift_blue [9:1];
    TMDS_mod10 <= (TMDS_mod10==4'd9) ? 4'd0 : TMDS_mod10+4'd1;
end
OBUFDS OBUFDS_red  (.I(TMDS_shift_red  [0]), .O(TMDSp[2]), .OB(TMDSn[2]));
OBUFDS OBUFDS_green(.I(TMDS_shift_green[0]), .O(TMDSp[1]), .OB(TMDSn[1]));
OBUFDS OBUFDS_blue (.I(TMDS_shift_blue [0]), .O(TMDSp[0]), .OB(TMDSn[0]));
OBUFDS OBUFDS_clock(.I(pixclk), .O(TMDSp_clock), .OB(TMDSn_clock));
endmodule
module TMDS_encoder(
    input clk,
    input [7:0] VD,  // video data (red, green or blue)
    input [1:0] CD,  // control data
    input VDE,  // video data enable, to choose between CD (when VDE=0) and VD (when VDE=1)
    output reg [9:0] TMDS = 0
wire [3:0] Nb1s = VD[0] + VD[1] + VD[2] + VD[3] + VD[4] + VD[5] + VD[6] + VD[7];
wire XNOR = (Nb1s>4'd4) || (Nb1s==4'd4 && VD[0]==1'b0);
wire [8:0] q_m = {~XNOR, q_m[6:0] ^ VD[7:1] ^ {7{XNOR}}, VD[0]};
reg [3:0] balance_acc = 0;
wire [3:0] balance = q_m[0] + q_m[1] + q_m[2] + q_m[3] + q_m[4] + q_m[5] + q_m[6] + q_m[7] - 4'd4;
wire balance_sign_eq = (balance[3] == balance_acc[3]);
wire invert_q_m = (balance==0 || balance_acc==0) ? ~q_m[8] : balance_sign_eq;
wire [3:0] balance_acc_inc = balance - ({q_m[8] ^ ~balance_sign_eq} & ~(balance==0 || balance_acc==0));
wire [3:0] balance_acc_new = invert_q_m ? balance_acc-balance_acc_inc : balance_acc+balance_acc_inc;
wire [9:0] TMDS_data = {invert_q_m, q_m[8], q_m[7:0] ^ {8{invert_q_m}}};
wire [9:0] TMDS_code = CD[1] ? (CD[0] ? 10'b1010101011 : 10'b0101010100) : (CD[0] ? 10'b0010101011 : 10'b1101010100);
always @(posedge clk) TMDS <= VDE ? TMDS_data : TMDS_code;
always @(posedge clk) balance_acc <= VDE ? balance_acc_new : 4'h0;
endmodule
and ucf
//global system clock
NET "pixclk"        LOC = A10   | IOSTANDARD = LVTTL;
//# HDMI Out (J3)
NET "TMDSp_clock" LOC = "C13" | IOSTANDARD = TMDS_33 ; # Clock
NET "TMDSn_clock" LOC = "B14" | IOSTANDARD = TMDS_33 ;
NET "TMDSp[0]"      LOC = "B10" | IOSTANDARD = TMDS_33 ; # Blue
NET "TMDSn[0]"      LOC = "A11" | IOSTANDARD = TMDS_33 ;
NET "TMDSp[1]"      LOC = "C11" | IOSTANDARD = TMDS_33 ; # Red
NET "TMDSn[1]"      LOC = "A12" | IOSTANDARD = TMDS_33 ;
NET "TMDSp[2]"      LOC = "B12" | IOSTANDARD = TMDS_33 ; # Green
NET "TMDSn[2]"      LOC = "A13" | IOSTANDARD = TMDS_33 ;
