In the AC input section of a PCB, I found a resistor (in parallel with an X capacitor) with 5 color bands:
        BLACK - GOLD - YELLOW - GRAY - BLUE(LIGHT BLUE)
Sorry because now I do not have anything to take a picture of it.
It's probably rated 2W and the PCB is made in Japan.
If I interpret it from left to right, the result is a 400 MOhms 0.25 % resistor. This is clearly wrong for a bleeder.
If I interpret it from right to left, the result is still unreasonable(68.4 Ohm). The precision is unknown as black isn't coded for any tolerance.
How should I interpret this resistor ?
    \$\begingroup\$ What is the colour of the body of the resistor? Brown? Blue? Green? \$\endgroup\$ Jul 12, 2018 at 14:37
  • \$\begingroup\$ @AndrewMorton Blue, lighter blue \$\endgroup\$
    – Long Pham
    Jul 12, 2018 at 14:39
It is a 680K 5% resistor. You're reading it backwards.
The black band is over the end cap, and should be on the right-hand side when reading the resistor. It is just to indicate orientation. Fairly common on Asian parts.
    \$\begingroup\$ I can't accept an answer in 5 minutes (lol). \$\endgroup\$
    – Long Pham
    Jul 12, 2018 at 14:41
  • \$\begingroup\$ Hmmm. Strange. I haven't seen this in general guildlines. \$\endgroup\$
    – Long Pham
    Jul 12, 2018 at 14:43
