I am trying to use Altium's multi-board design tool to connect 2 PCB's.
The PCB's will be connected with a right angle, male-male pin header (shown in image below).
Bottom PCB: Motherboard Top PCB: Daughterboard
My project structure looks like this:
- Project.PrjMbd
- Source Documents
- Project.MbsDoc
- Project.MbaDoc
- Daughterboard.PrjPCB
- Source Documents
- Daughterboard.SchDoc
- Daughterboard.PcbDoc
- Source Documents
- Motherboard.PrjPCB
- Source Documents
- Motherboard.SchDoc
- Motherboard.PcbDoc
- Source Documents
- Source Documents
I intend to join the two boards using only one pin header. The trouble is that both boards need to have the header library component so that the correct pads and nets are connected.
Does Altium have a mechanism for doing this?
EDIT: I do have the System:Connector parameter added to the header library component.
