I simply want to control a stepper motor with an Arduino and I need the TMC2130 to ensure it runs very quiet. I've done a lot of searching and somehow can't find how to actually wire it to an Arduino and a power source.
I can find Arduino libraries and sample code galore though. I have seen wiring diagrams but they only use the TMC eval kit which I don't want to buy.
Is a TMC2130 and Arduino all I need as far as ICs or boards go? Anyone have experience with this?
This schematic reminds me of those DRV8825 schematics. Pretty simple to follow:
TMC2130 Arduino Wiring Schematic
Source: TC2130 Arduino Wiring (Last checked: 07/13/2018)
Looks pretty straight forward to me, there is a diagram in the datasheet on page 5. I would strongly recommend you read and understand the datasheet, if you don't your more than likely to start it up for the first time and not have functionality. You will then read the datasheet until you understand it and find the problem.
The first thing to check in a datasheet is absolute maximum ratings, do not exceed these conditions.
The SPI bus is connected to the arduino (make sure the logic levels are the same)
It appears that the STEP and DIR ports can be driven from the microprocessor, and the motor controlled that way (and may be able to be controlled through the spi bus as well)
An example schmatic is found here for the eval board.
    \$\begingroup\$ There's also a Blog showing all the pins for Arduino UNO here: blog.trinamic.com/2017/06/27/… The eval board has only the TMC2130 on it, so it's just copying the pin numbers through. \$\endgroup\$ Jul 13 '18 at 3:00
Most of us lazy folk just use a RAMPS board for our stepper drivers with the Arduino. The schematics are available, but it's just so easy to buy a RAMPS board.
A RAMPS board is commonly used to drive the 4 stepper motors found in most 3D printers but it is general purpose and can drive many positioning applications.
    \$\begingroup\$ Oh ok! I didn't know anything about RAMPS other than it's typically used for 3D printing so I guess I didn't even consider it. I'll look into it, thanks! \$\endgroup\$
    – conn250
    Jul 14 '18 at 12:18
Just because I still didn't knew what I was doing after the answers even tho they are helpful, a bit comprehension in knowledge for beginners, since the driver board differentiates f.e. from a L298n driver board.
In short, a driver board like the TMC 2130 only need +5V and GND, a Digital pin for DIR and STEP. EN can be pulled to a GND pin to work f.e. with the AccelStepper arduino library but would miss out many great features. To take advantage of them, my 6 step guide to hopefully safe you a day or two working through the Trinamic website for a quick and run.
In general all that has to be done is:
  1. checking the data sheet of the stepper motor for the Imax current. In my case: 17hs4401 the motor has 1.7A "Rated Current". That means the TMC 2130 would work but wouldn't be able to run in stealth mode but would work since...
"The maximum settable motor current is 1.77A RMS (0.11Ohm sense resistors), but the SilentStepSticks can only be used up to 1.2A RMS." (https://wiki.fysetc.com/TMC2130/#motor-current-setting)
Motor Phase Current max 2A RMS, 2.8A Peak
(https://wiki.fysetc.com/Silent2209/#technical-specifications)
So I went for the later TMC 2209 (In my opinion a better choice in every aspect to the TMC 2130 and even tho the same hint of 1.2A appears but the RMS is at 2A so it works.)
EDIT: Teemalut, the library creator clarified a few points that I misinterpreted in the documentation:
Current rating doesn't limit your choice of stepping mode. The 1.2A limit is a practical thermal limit. I'd rather not call 2209 to be better in every way than the 2130. It lacks some options and adds some and ultimately it'll be up to the user to choose the driver. I tend to favor the SPI ones because they're easier to work with.
If you don't have software control over the driver you have to adjust the resistor manually. Else you can skip point 2 and 3.
  1. To do this manually, put a multi meter to the ground pin of the Motor output (next to the 3 empty holes) and the other wire to the Vref hole/pin and check the data sheet again where Vref has to be measured since that changes even from version to version of the board layout. Could be the right pin or the left of the 3 pins or somewhere else. (And yes, at this point you have to get a multi meter, a cheap discounter one for 5 bucks will do it tho to not fry the driver board)
(The multi meter on direct current voltage ⎓, NOT alternating current ~; Switch the multi meter selection to be as near as, but bigger than, the voltage to measure, f.e. 20V range for the 2.4V measuring) The higher the range difference, the less accurate the measuring will get
There actually is a calculator for that in the homepage just for training the formula:
Vref = (Irms * 2.5V) / 1.77A = Irms * 1.41 = Imax
so Vref = (1,7A * 2,5V) / 1,77A = 1,4V
  1. Putting on the 5V logic voltage VIO & GND and the 12V motor voltage VM& GND next to it. Don't connect the motor and not necessarily the GND pins with each other, they can be separated. Now take a really small screwdriver and adjust the screw on the potentiometer until the calculated direct current voltage appears.
You might have to wait a bit until the voltage stops jumping because the TMC 2209 or TMC 2130 driver is adjusting at first connection to the voltage until you be able to adjust to - in my case 2.4V for a 1.7A bipolar stepper motor.
That was the hardest part.
  1. The motor Types should be in the TMCStepper library of the Arduino IDE. There is actually an example sketch of the TMC2209 and the library also works with the TMC 2130 and takes advantage of many features of the TMC drivers (https://github.com/teemuatlut/TMCStepper)
I am using the Arduino Mini clone
The Enable and Direction pin should be digital pins and the Step pin, SW_RX and SW_TX PWM pins. The TMC 2209 and TMC 2130 work with 3,3V and 5V so nothing to worry here.
All the pins can be just normal digitalIO pins. https://github.com/teemuatlut/TMCStepper/pull/146#issuecomment-684010156
  1. Change the pins according to DigitalIO of your board and uncomment the stuff according to the following code example
    #define EN_PIN           7 // Enable
    #define DIR_PIN          8 // Direction
    #define STEP_PIN         9 // Step
    #define SW_RX            5 //
    #define SW_TX            6 //
    #define SERIAL_PORT  Serial // [Serial1 to Serial]
    #define DRIVER_ADDRESS 0b00 // TMC2209 Driver address according to MS1 and MS2
    #define R_SENSE 0.11f // Match to your driver
                          // SilentStepStick series use 0.11
                          // UltiMachine Einsy and Archim2 boards use 0.2
                          // Panucatt BSD2660 uses 0.1
                          // Watterott TMC5160 uses 0.075
    // Select your stepper driver type
    //TMC2209Stepper driver(&SERIAL_PORT, R_SENSE, DRIVER_ADDRESS);
    TMC2209Stepper driver(SW_RX, SW_TX, R_SENSE, DRIVER_ADDRESS); //Uncomment this if you connected SW_RX and SW_TX
That was it.
So I got the following configuration:
  • Arduino Digital Pin 7 --> Enable to EN
  • Arduino Digital Pin 8 --> Direction to DIR
  • Arduino Digital Pin 9 --> Step to STEP
  • Arduino Digital PIN 5 --> SW_RX to RX
  • Arduino Digital PIN 6 --> SW_TX to TX
  • Arduino +5V or +3.3V --> to VIO
  • Arduino GND --> to GND next to VIO
  • +12V >2A Power source --> to VM
  • GND >2A Power source --> to GND next to VM
  • Motor A+ --> A2
  • Motor A- --> A1
  • Motor B+ --> B1
  • Motor B- --> B2
(It would also work to ,just connect Step and Direction to the arduino, with the AccelStepper Library, and pull EN to Arduino GND and leave the others open, to make the motor work, but lots of features of the TMC wouldn't be used and the motor would probably be louder and "eat" more power. But that's a solution if you only got one digital and one pwm pin left on your arduino.)
I hope someone will safe a day reading through documentation to make sense of how that driver board works with this post.
    \$\begingroup\$ Hello and many thanks for your comprehensive tutorial. Just a side-note - if someone is going to use the TMCStepper library together with a ESP32 as I did, you need to use the HardwareSerial, due to compatibility issues. Please see github.com/teemuatlut/TMCStepper/issues/… for more details \$\endgroup\$
    – karlitos
    Nov 6 '20 at 8:21
    \$\begingroup\$ @karlitos Happy it helped you :) Thanks for your response. \$\endgroup\$
    – Ivanovic
    Nov 6 '20 at 22:50
