I need a little help from experienced people. I want to control a Peltier element with a microcontroller, with PWM. May? The peltier element has the following parameters: Imax=8.3 A, Vmax=3.8V.Ok... I have a 12 volt source for example, and the circuit need to be able to support 8 amps? What circuit can i use to reduce te voltage, And that circuit will support 8 amp ?
  • \$\begingroup\$ A link to the peltier element data sheet is needed. \$\endgroup\$ – Andy aka Jul 13 '18 at 10:19
  • \$\begingroup\$ farnell.com/datasheets/… \$\endgroup\$ – Andrei Toderita Jul 13 '18 at 10:50
  • \$\begingroup\$ Please, edit your post to include the link. This will improve your answer. Comments are only a temporary mean of communications here. They may not last. And the question needs to stand on its own with all the needed information. \$\endgroup\$ – Lorenzo Donati Jul 13 '18 at 13:44
    \$\begingroup\$ BTW, all of your concerns are covered here. The only detail missing is calculations for your specific case. TL;DR: you cannot use PWM directly to drive a Peltier cell, you need to convert it to a proportional DC level to avoid damaging the cell. \$\endgroup\$ – Lorenzo Donati Jul 13 '18 at 13:47
