I have a Piezo buzzer that has an internal transducer so is able to take 24VDC and work. This one has a continuous sound. Just a beeeeeeeeeeeeeeeeeeeeeeeee...
I have a 24V output that needs to power an alarm sound (has to be piezo). The alarm has to be On/Off, a beep beep beep. Not particularly concerned about the exact frequency, or sound, or even how long the beep and pause is for. Just has to be a beep, and preferably customizable if required.
I thought of using an ATTiny but then I need a switching regulator to provide 5V to the microcontroller, and then another power transistor to run the buzzer. That makes 3 fairly large components (footprint is important) and the price goes over £10. I thought of 555 but definitely, the footprint is too large because even the 555 won't take 24V.
I cannot for the life of me figure out how to make the buzzer switch on and off, like a slow flip-flop, or PWM maybe, without using a microcontroller.
By the way, THIS and THIS is exactly what I am talking about. I will definitely use these for my application, but I need to figure out how to make a continuous one pulse. Or even better, how to take just a regular Piezo element (without internal transducer) and get any frequency I want out of it, with as few components as possible. I can do it with an ATTiny as mentioned above, but running it 24V introduces two additional components.
I highly appreciate any help I can get.
closed as unclear what you're asking by Chris Stratton, Sparky256, RoyC, JYelton, Bimpelrekkie Aug 8 at 14:06
Please clarify your specific problem or add additional details to highlight exactly what you need. As it's currently written, it’s hard to tell exactly what you're asking. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
    \$\begingroup\$ You keep telling us that the footprint is important but you never tell us how big it can be. What do you mean by a "continuous one pulse"? What do you really mean by "any frequency I want"? \$\endgroup\$ – Elliot Alderson Jul 13 '18 at 11:10
Use an LM122 configured as an oscillator. Tie the output as
If you had a 12 volt supply, you could use a 555, but that won't work at 24 volts.
  • \$\begingroup\$ Looks good but I cannot find the LM122 to purchase, unfortunately. I think i'll try the astable multivibrator. \$\endgroup\$ – M.. Jul 16 '18 at 12:25
-1
You could make the classic two-transistor multivibrator and set it to oscillate at the beeper on/off rate. Use a third transistor to then switch the power to the beeper.
Don't forget to put a reverse diode across the beeper. Piezo elements can have kickback similar to what inductors do.
  • \$\begingroup\$ I think this is it. I initially thought about an astable multivibrator but for some reason dropped that idea because I thought it would be less efficient. I will test this and let you know if it worked or not. Thank you for your help. \$\endgroup\$ – M.. Jul 16 '18 at 12:41
