I'm trying to come up with a design for controlling a 24VAC water valve with an arduino.
My current design :
I want to use a BT1308W TRIAC controlled by an arduino pin to activate the vale, I'm also using a smbj48ca TVS diode to suppress spike generated by the solenoid when it's de-energized. I was using a similar design using a relay and the arduino was reboting randomly when the solenoid was closed, after adding the TVS diode it's not happening but is the correct use for this diode?
You need a back-to-back (or bidirectional) TVS diode i.e. one rated for AC. At the moment if you apply AC to the terminals (VAC1 and 2) and energize the triac it will short out the AC supply on positive half cycles.
  • \$\begingroup\$ You are right, the chosen smbj48ca is a bidirectional TVS diode, the symbol was wrong \$\endgroup\$
    – Marc
    Jul 13, 2018 at 14:32
  • \$\begingroup\$ Then you should be good to go. \$\endgroup\$
    Jul 13, 2018 at 14:40
  • \$\begingroup\$ Shouldn't pin 1 of the triac have a connection to the DC part of the circuit as well? \$\endgroup\$
    – Maple
    Jul 13, 2018 at 21:45
  • \$\begingroup\$ @Maple yes it should and the OP should make that clear in his circuit hence how could he have proven the original design worked albeit causing EMI issues. Good spot. \$\endgroup\$
    Jul 14, 2018 at 8:44
  • \$\begingroup\$ Why should the TRIAC have a connection to the DC part of the circuit? A triac is not just sold state relay? \$\endgroup\$
    – Marc
    Jul 20, 2018 at 11:07
