Suppose only one multiplexer and one inverter are allowed to be used to implement any Boolean function of n variables. What is the minimum size of the multiplexer needed?
Answer is: 2n−1 to 1
Any help provided to understand this question is appreciated.
circuit input n goes to the inverter circuit inputs 1 to n-1 go the multiplexer address lines
mux data inputs are wired to 1,0,n or not(n) as required to produce your function on the output.
  • \$\begingroup\$ what would happen if we are not given with NOT GATE/INVERTER? \$\endgroup\$ Commented Jul 15, 2018 at 11:44
  • \$\begingroup\$ then you would not have not n as a choice for mux inputs so you'd only be able to fully handle functions of n-1 bits. \$\endgroup\$ Commented Jul 16, 2018 at 6:05
