The datasheets ambiguously say...
A leap year is set whenever the year value is a multiple of four (such as 04, 08, 12, 88, 92, or 96).
Is zero a multiple of four? This is more of a philosophical question than a specification. The shown series starts at 4 and ends with 96, strongly hinting that the good folks at Seiko do not think that zero is a multiple of four.
Turns out to be a critical fact if you are trying to measure timespans - if you pick wrong then any date after Mar 1, 00 may be off by a day!
  • \$\begingroup\$ Y2k bug anyone.... \$\endgroup\$ – Solar Mike Jul 15 '18 at 22:14
  • \$\begingroup\$ @SolarMike I was still rather young when people were freaking out about that problem but I remember when I was in college, I was thinking, "You'd think the year 2047 would pose more of a problem than 2000...." But I suppose if your only notation of the date were the last two digits, then I can see why people would freak out. \$\endgroup\$ – KingDuken Jul 15 '18 at 22:34
6
Despite the misleading series in the datasheet, the RX8900 does consider the year "00" to be a leap year.
I tested this empirically by setting the date to Feb 28th, 00 and letting it roll to see what the next day was...
I also checked Feb 28th, 01 as a control... enter image description here
If you are looking at this question, then this code might be of use to you...
// This table of days per month came from the RX8900 datasheet page 9
static uint8_t daysInMonth( uint8_t m , uint8_t y) {
    switch ( m ) {
        case  1:
        case  3:
        case  5:
        case  7:
        case  8:
        case 10:
        case 12:    // Interestingly, we will never hit 12. See why?
                    return 31 ;
        case  4:
        case  6:
        case  9:
        case 11:
                    return 30 ;
        case  2:
                    if ( y % 4 == 0 ) {         // "A leap year is set whenever the year value is a multiple of four (such as 04, 08, 12, 88, 92, or 96)."
                                                // Empirical testing also shows that 00 is a leap year to the RX8900
                                                // https://electronics.stackexchange.com/questions/385952/does-the-epson-rx8900-real-time-clock-count-the-year-00-as-a-leap-year
                        return 29 ;             // "February in leap year 01, 02, 03 ... 28, 29, 01
                    } else {
                        return 28;              // February in normal year 01, 02, 03 ... 28, 01, 02
    __builtin_unreachable();
static const uint32_t rx8900_days_per_century = ( 100UL * 365 ) + 25;       // 25 leap years in every RX8900 century
// Convert the y/m/d values from the RX8900 to a count of the number of days since 00/1/1
// rx8900_date_to_days( 0 , 1, 1 ) = 0
// rx8900_date_to_days( 0 , 1, 31) = 30
// rx8900_date_to_days( 0 , 2, 1 ) = 31
// rx8900_date_to_days( 1 , 1, 1 ) = 366 (00 is a leap year!)
static uint32_t rx8900_date_to_days( uint8_t c , uint8_t y , uint8_t m, uint8_t d ) {
    uint32_t dayCount=0;
    // Count days in centuries past
    dayCount += rx8900_days_per_century * c;
    // Count days in years past this century
    for( uint8_t y_scan = 0; y_scan < y ; y_scan++ ) {
        if ( y_scan % 4 == 0 ) {
            // leap year every 4 years on RX8900
            dayCount += 366UL;      // 366 days per year past in leap years
        } else {
            dayCount += 365UL;      // 365 days per year past in normal years
    // Now accumulate the days in months past so far this year
    for( uint8_t m_scan = 1; m_scan < m ; m_scan++ ) {      // Don't count current month
        dayCount += daysInMonth( m_scan , y );       // Year is needed to count leap day in feb in leap years.
    // Now include the passed days so far this month
    dayCount += (uint32_t) d-1;     // 1st day of a month is 1, so if it is the 1st of the month then no days has elapsed this month yet.
    return dayCount;
  • \$\begingroup\$ what board is that? \$\endgroup\$ – james Jan 26 '19 at 17:01
  • \$\begingroup\$ @james It is the PCB inside this device. LMK if you plan on using the RX8900. It is a good chip, but not so good documentation so I might be able to save you some head banging . \$\endgroup\$ – bigjosh Jan 27 '19 at 1:02
