I'm involved in a project and part of it involves heat coefficient and heat conductance. What's the relationship between the two, given that the SI unit for heat coefficient is \$W/mK\$ and the SI unit for heat conductance is \$W/m^2K\$?
\$W\$ - Heat Energy (Watts/Joules per second)
\$m\$ - Length
\$m^2\$ - Area
\$K\$ - Difference in Temperature (Kelvin)
Does anyone know the above parameters for steel? Especially heat conductance.
Thank you.
  • \$\begingroup\$ What does googling this tell you? \$\endgroup\$
    Commented Jul 16, 2018 at 11:30
  • \$\begingroup\$ Googling doesn't really explain much on the conductance. Mostly heat co-efficient. \$\endgroup\$
    – Just Tom
    Commented Jul 16, 2018 at 11:34
    \$\begingroup\$ Actually, you've got it backwards: heat transfer coefficient is \$W/m^2K\$ and thermal conductivity is \$W/mK\$. \$\endgroup\$
    – Dave Tweed
    Commented Jul 16, 2018 at 12:06
  • \$\begingroup\$ Mechanical/Thermal Engineering problem? \$\endgroup\$
    – user103380
    Commented Jul 16, 2018 at 14:16
  • \$\begingroup\$ I appreciate the correction. \$\endgroup\$
    – Just Tom
    Commented Jul 18, 2018 at 9:02
There is no intrinsic relationship between the two. Heat transfer coefficient ( \$W/m^2K\$) is a measure of how readily heat moves across the interface between two different materials, while thermal conductivity (\$W/mK\$) is a measure of how easily it moves within a single material.
