I am trying to write a verilog code for a Fibonacci sequence generator. It's output will be nth Fibonacci number where n is the output of the count. The code works for count = 2. But when the count increases, all the specified register values goes to 0. I am suspecting the error might be in the always block that contains the case statement. How can I solve the problem?
module fib(clk, reset, count, out, prev,present, temp);
// This module generates nth fibonacchi number, where n is the output of the count
    input clk, reset;
    output reg[7:0] count;
    output [7:0]out;
    output reg [7:0]prev, present, temp;
    //state register
    always @(posedge clk)
        if(reset==1) count = 1;
        else count = count + 1;
    //next state logic
    always @(count[0])
    case(count)
    8'b00000001:begin
                prev = 8'bxxxxxxxx; present = 8'bxxxxxxxx;
                end
    8'b00000010:begin
                prev = 8'b00000000; present = 8'b00000001;
                end
    default: begin
                temp = present;
                present = present + prev;
                prev = temp;
            end
    endcase
    //output logic
    assign out = present;
endmodule
  • \$\begingroup\$ Comments are not for extended discussion; this conversation has been moved to chat. \$\endgroup\$
    – Dave Tweed
    Jul 19, 2018 at 19:23
You are writing Verilog as if it is a standard programming language. HDL languages work rather different.
  1. In your count section use non-blocking assignments.
  2. In your always section you are generating latches. The whole 'always' section should be controlled by a clock as you have 'memory' elements in there: You want the values of prev, temp and present to be 'remembered'.
  3. It is common (good) practice to always use begin-end sections. In your case it works because you have a single statement (if and case).
  4. The Fibonacci sequence starts with 1,1 which is not in your code.
  5. If you use non-blocking assignments, you no longer need the 'temp' variable:
prev    <= present
present <= present + prev;
Side notes:
  1. A name like 'out' is not very descriptive. Even if you write short test snippets use descriptive names.
  2. It is bad practice to use always @( variable ) these days. It can lead to simulation synthesis mismatches. You should use always @( * ) or alway_comb.
  3. Comment as at the bottom of your example is rather superfluous:
//output logic
  • \$\begingroup\$ begin/end isn't needed if there's only one statement in a block. Stylistically I'd rather see it than check carefully whether it's needed, but I don't think this is what's causing OP's unexplained behavior. \$\endgroup\$
    – The Photon
    Jul 17, 2018 at 15:27
  • \$\begingroup\$ Thanks for your input. Finally the code has run somewhat perfectly after I initialized used posedge clk for both always block. Could you comment on why combinational assignment didn't work here? The pastebin link for the code is given: pastebin.com/jmC6aw1L \$\endgroup\$
    – user308177
    Jul 17, 2018 at 16:41
  • \$\begingroup\$ @ThePhoton : Yes I noticed, I will update. @user308177: You made some weird combinatorial loop with latches. HDL is like hardware. If you write e.g. a=b+1; b=a; you make a 'circuit' where the output goes straight back into the input. The @(posedge clk)breaks the loop with a register. \$\endgroup\$
    – Oldfart
    Jul 17, 2018 at 20:20
