I'm learning some basic electronics, and I'm using an old textbook (Basic Electronics for Scientists, Brophy, 1966) to wrap my head around some fundamentals.
At the moment, I'm looking at potentiometers, and I'm trying to understand a particular circuit in the textbook (I've included a photo of the circuit diagram.) The potentiometer has a secondary circuit, which is connected to an ammeter and a reference voltage source. The textbook suggests that the variable resistor \$R_A\$ should be adjusted so that the current passing through the ammeter labelled \$M_1\$ is equal to zero. However, I cannot see how this is possible given the orientation of the reference voltage source \$V_S\$, both conceptually and using Kirchhoff's voltage/current laws.
Can somebody tell me at a glance whether or not the book is misprinted, and if the terminals on \$V_S\$ are supposed to be swapped around the other way? If it is a simple misprint, then I can understand how everything should be working. If it isn't a misprint, I'd really like some feedback on my working re: my KVL analysis of the circuit (which I'll provide). The circuit diagram - is the orientation of Vs correct?
I'm still not 100% sure that I understand how this works. I'm considering the simplified example below. I've condensed \$R_A\$ and all of the series resistors into a single (variable) resistor, although I've left \$R_S\$. Please excuse my terrible sketch:
So, my question is, under what conditions can \$I_3\$ ever be zero? Here's my analysis of the problem:
First, let's consider the loop abcd. This yields the following equation (KVL):
$$ V - I R_1 - I_2 R_{S} = 0 $$
Next, consider the loop abef, which yields:
$$ V - I R_{1} + V_{s} = 0 $$
Finally, consider the current at junction c:
$$ I = I_2 + I_3 $$
I can substitute this expression for \$I\$ into my two KVL equations. This gives me:
$$ V - (I_2 + I_3) R_1 - I_2 R_{S} = 0 $$
$$ V - (I_2 + I_3) R_{1} + V_{s} = 0 $$
I can now rearrange these two equations by putting the voltages on the left-hand side, yielding:
$$ V = (I_2 + I_3) R_1 + I_2 R_{S} $$
$$ V + V_{s} = (I_2 + I_3) R_{1} $$
Rearranging the second expression for \$I_2\$ yields:
$$ \frac{(V + V_S) - R_1 I_3}{R_1} = I_2 $$
And substituting this value for \$I_2\$ into the \$V =\text{ ...}\$ expression gives me a somewhat messy equation:
$$ V = \left(\frac{(V + V_S) - R_1 I_3}{R_1} + I_3\right) R_1 + \frac{(V + V_S) - R_1 I_3}{R_1} R_{S} $$
Expanding this out (I'll skip a few steps) gives me:
$$ 0 = V_S + \frac{R_S}{R_1}V + \frac{R_S}{R_1}V_S - R_SI_3 $$
Finally, rearranging for \$I_3\$ gives me my final expression:
$$ I_3 = \frac{1}{R_S}V_S + \frac{1}{R_1}(V + V_S) $$
Clearly, every term on the right-hand-side of this equation is positive, and neither \$V\$ nor \$V_S\$ can be negative, because I'm (hopefully) accounted for their polarity when I initially set up my simultaneous equations. So what am I missing? How can \$I_3\$ ever be equal to zero? At first I thought that adding an unknown voltage across the series resistors would change something, but after I went back to have a look, I realised that I still don't understand the problem.
Ah, one of the joys of being an old fart is seeing instruments I've used displayed as museum pieces. Such as a Biddle Portable Potentiometer and a similar device equipped with an optical galvo. Similar to this one.
Anyway, the voltage across the divider chain bucks the unknown voltage. When it is exactly equal then no current flows through M2 (typically a very sensitive galvonometer). Your analysis should yield a voltage of the same polarity as the unknown, the book is correct. Maybe you have an issue with the 0V reference, but without your work it's hard to guess.
  • \$\begingroup\$ Thank you very much for getting back to me. Perhaps I'm misreading the book - it seemed to imply that one could adjust the variable resistor until no current flowed through M1 before the unknown voltage that one wished to measure was introduced into the circuit. Is this still possible? I'm going to include my KVL analysis in my original question. \$\endgroup\$
    – cbg
    Commented Jul 18, 2018 at 4:08
  • \$\begingroup\$ @cbg Nope. You press a button and the galvo whacks over to one side or the other and you adjust the potentiometer voltage until the galvo no longer moves when you press the button. You can actually measure microvolts with this method! And the long term stability is very, very good with wirewound resistors, particularly if calibrated with a standard cell (but that's another story). The supply used to be Hg D-cells on one of the ones I used. \$\endgroup\$ Commented Jul 18, 2018 at 4:11
    \$\begingroup\$ This makes much more sense - thank you so much! The book gave me the impression that 1) you adjusted Ra until there was no current flowing through M1, and then 2) you connected your unknown voltage to the main circuit. Clearly that's incorrect, and I really couldn't understand how it was possible. Your help is very much appreciated. \$\endgroup\$
    – cbg
    Commented Jul 18, 2018 at 4:23
  • \$\begingroup\$ P.S. It's quite possible the person writing the book had never used such an instrument. They cost about as much as a small car at the time. \$\endgroup\$ Commented Jul 18, 2018 at 5:12
    \$\begingroup\$ Aaah I think I see where the confusion comes from. You don't want to deplete he reference voltage , which is why it's only connected when you press the button. So, ideally you adjust to the correct potentiometer setting, and only press the button to confirm. In practice of course that's impossible, so you see the needle kick and release the button immediately, adjust to your best guess, and try again (a bit like a successive approximation ADC). For really critical measurements ... \$\endgroup\$
    – user16324
    Commented Jul 18, 2018 at 9:41
