I am trying to set under voltage, over voltage and over voltage clamping limits in a circuit for Overvoltage Output Regulator with Reverse Current Protection using LTC4364 device. The LTC4364 uses an external resistor voltage divider to set the over, under voltage and overvoltage clamping(FB pin) limit set points.
In the datasheet they have some example circuits with OV, UV and Overvoltage clamping limits with Resistor voltage divider but i am not able to understand how they calculated resistor values for certain OV and UV limits.
with Vin=12V and to set UV to 6V they have used 383K(R1) and 100K(R2) as well to set OV to 60V they have used 475K(R1) and 10K(R2). I am not able to get these values with basic voltage divider fromula.
My question is I want to set UV to 18v and OV to 32 V and overvoltage clamping to 35V at FB pin with Vin as 24V.Can anyone help me how to calculate resistors values for desired set limits.
The LTC4364 data sheet is here LTC4364
