I am trying to solve this question:
problem
However, I am having difficulties solving as I only have come across circuits which are initially closed then opened, not vice versa as is the case here. Specifically, I am trying to construct the simplified circuit for t<0. Usually, for the latter case, the inductor is a short circuit for the 20 Ohm resistor if t<0. However, I am unsure how it acts as this circuit starts open and then becomes closed.
So far, all I have been able to do is to a source transformation, making the current source a 150 V voltage source and combining the 10 and 5 Ohm resistors.
Any help would be appreciated, thanks!
for t<0 you have this circuit :
first, you should calculate IL for t<0: enter image description here
When SW1 move from a to b we have this circuit:
the equivalent resistor of 5 and 20 ohm is 4 So you have :
to obtain voltage equation we derivate the current equation:
  • \$\begingroup\$ Thanks! From my understanding, in the second last equation for V = L di/dt, you used I = 10e^-80.2*t. Where did this come from? I assumed it came from the line above, however I(t) = 10e^-0.2 * e^-80*0.01 doesn't equal such. \$\endgroup\$ – Richard Robinson Jul 19 '18 at 20:11
  • \$\begingroup\$ I just calculate C1 int that line, not i. \$\endgroup\$ – Rashid Jul 20 '18 at 10:54
  • \$\begingroup\$ Where did you get the i in di/dt from then? \$\endgroup\$ – Richard Robinson Jul 20 '18 at 16:22
  • \$\begingroup\$ In the second circuit we have i=c1*e^(-80t) where c1 is 10e^(-0.2) . To obtain voltage we need to calculate Ldi/dt . \$\endgroup\$ – Rashid Jul 20 '18 at 16:40
  • \$\begingroup\$ But I = c1*e^(-80t) = 10e^(-0.2) doesn't equal 10e^(-80.2t) \$\endgroup\$ – Richard Robinson Jul 20 '18 at 18:50
