I have a TIP31c transistor, I need a 2N2222 for an Arduino project to drive small dc motors with PWM, I found both transistors are NPN, but I don't want to hurt my Arduino, is the swap possible?
It should work if you get the pinning correct. The TIP31C is generally going to be lower current gain than the 2N2222 so it will require a higher base current for a given load.
If your small motor load is a low current device truly compatible with the ratings of the 2N2222 then I see no reason that would keep you from trying the TIP31C.
| improve this answer | |
