I'm looking at this 10A, 277VAC relay and wondering if there is sufficient spacing between the low voltage (3.5V, 100mA) and the high voltage(277VAC, 10A). The foot print looks like this:
Are the 5V leads too close to the high voltage leads? Why aren't the high voltage leads on one side and the low voltage leads on the other side? Also, the use case is to be mounted on FR-4 and there will be a fuse before the high voltage goes to the relay.
