I have been working on using the ethernet phy on my Nexys4 DDR for the last few weeks. Over the last few days I have been particularly frustrated with one issue I was having with my rx module. I have pasted the code bellow. My module goes through three different states. Waiting for preamble, signaling the start of frame, and receiving the body of the packet. These three states are stored using the state register. The design works fine in the simulator and when I first tested it on the card.
To test it I have been using chipscope and I had reg state marked as debug. Then I removed the chip scope probes and everything started to fail. It would signal the start of frame and then nothing else. Through experimentation I found that when I have a probe on the state register the whole design works, but if I remove that probe the design falls apart. At first this seemed like a timing issue since the eth_* signals come from the ethernet phy directly (I drive the phy with a clock 45 degrees out of phase from clk_mac.) I added a pipeline stage between those signals and my combination logic and it was still failing. Now I don't think it is a timing issue since it is unlikely that I would get a valid preamble and first byte if those signals were wrong.
After some more experimentation I noticed the following in the synthesis log....
State | New Encoding | Previous Encoding
STATE_PREAMBLE | 0 | 000
STATE_SOF | 1 | 001
INFO: [Synth 8-3354] encoded FSM with state register 'state_reg' using encoding 'sequential' in module 'eth_rx'
It appears that vivado is optimizing out the upper bits of the state register. (Note: before someone points it out I know I should probably only have [1:0] instead of [2:0] but my design started out with more states than I ended up needing and I haven't changed it yet.) Either way vivado is removing STATE_RECV which requires the state[1] bit to be set. By adding the chipscope I was preventing vivado from doing what seems like an illegal optimization. I think this is a bug with vivado. Has anyone else seen this or is there something wrong you see with my verilog? I am using vivado 2018.1.
`timescale 1 ns / 1 ps
module eth_rx
input clk_mac,
input rst_n,
input eth_crsdv,
input eth_rxerr,
input [1:0] eth_rxd,
(* mark_debug = "true" *)
output reg rx_vld,
output reg [7:0] rx_dat,
output reg rx_sof,
output reg rx_eof,
output reg [10:0] rx_len,
output reg rx_err
`include "util.vh"
reg eth_crsdv_b;
reg [1:0] eth_rxd_b;
reg eth_rxerr_b;
always @(posedge clk_mac) begin
eth_crsdv_b <= eth_crsdv;
eth_rxd_b <= eth_rxd;
eth_rxerr_b <= eth_rxerr;
end
reg [63:0] data_buffer;
reg [63:0] next_data_buffer;
if(rst_n)
data_buffer <= next_data_buffer;
else
data_buffer <= 0;
end
reg [10:0] frame_idx, next_frame_idx;
reg [1:0] dibit_cnt, next_dibit_cnt;
dibit_cnt <= next_dibit_cnt;
frame_idx <= next_frame_idx;
end
reg next_rx_vld;
reg next_rx_sof;
reg next_rx_eof;
reg [10:0] next_rx_len;
reg [7:0] next_rx_dat;
reg next_rx_err;
rx_vld <= next_rx_vld;
rx_dat <= next_rx_dat;
rx_sof <= next_rx_sof;
rx_eof <= next_rx_eof;
rx_len <= next_rx_len;
rx_err <= next_rx_err;
end
localparam STATE_PREAMBLE = 0;
localparam STATE_SOF = 1;
localparam STATE_RECV = 2;
reg [2:0] state;
reg [2:0] next_state;
if(rst_n)
state <= next_state;
else
state <= STATE_PREAMBLE;
end
wire [31:0] crc32_code;
crc32 crc32_inst
.clk (clk_mac),
.rst (next_rx_sof && next_rx_vld),
.vld (next_rx_vld && !next_rx_eof),
.data(next_rx_dat),
.crc (crc32_code)
always @* begin
next_state = state;
next_rx_vld = 0;
next_rx_eof = 0;
next_rx_sof = 0;
next_rx_err = 0;
next_rx_len = rx_len;
next_rx_dat = rx_dat;
next_frame_idx = frame_idx;
next_dibit_cnt = dibit_cnt + 1;
if(eth_crsdv_b && !eth_rxerr_b)
next_data_buffer = {eth_rxd_b, data_buffer[63:2]};
else
next_data_buffer = 0;
case(state)
STATE_PREAMBLE: begin
next_dibit_cnt = 0;
next_frame_idx = 0;
if(data_buffer == 64'hd555555555555555) begin
next_state = STATE_SOF;
end
end STATE_RECV, STATE_SOF: begin
if(eth_rxerr_b) begin
next_rx_vld = 1;
next_rx_eof = 1;
next_rx_vld = 1;
next_state = STATE_PREAMBLE;
end else if(eth_crsdv_b) begin
if(&next_dibit_cnt) begin
next_frame_idx = frame_idx + 1;
if(frame_idx >= 4) begin
next_rx_len = frame_idx - 3;
next_rx_vld = 1;
next_rx_dat = next_data_buffer[31:24];
next_rx_sof = state == STATE_SOF;
next_state = STATE_RECV;
end
end
end else begin
next_rx_eof = 1;
next_rx_vld = 1;
next_rx_err = crc32_code != bswap32(data_buffer[63:32]);
end
end
endcase
end
endmodule
UPDATE: I got rid of the FSM extraction and now it works fine...
localparam STATE_PREAMBLE = 3'b001;
localparam STATE_SOF = 3'b010;
localparam STATE_RECV = 3'b100;
//Override FSM because Vivado ignores STATE_RECV with auto
(* fsm_encoding = "none" *)
reg [2:0] state = STATE_PREAMBLE, next_state;
if(rst_n)
else
end
