9
I know people says code optimization should only bring out the hidden bug in the program, but hear me out. I am staying on a screen, until some input via an interrupt is met.
Here is what I see in the debugger. Notice the line inspected and the expression value intercepted. enter image description here
Code in image:
ui::Context::addEventListener(ui::EventType::JOYSTICK_DOWN, &constant_dynamic_handler);
while (true) {
    if (choice != 0) //debugger pause
        break;
ui::Context::removeEventListener(ui::EventType::JOYSTICK_DOWN, &constant_dynamic_handler);
if (choice == 1) goto constant;
else if (choice == 2) goto dynamic;
else if (choice == 3) goto reset;
else if (choice == 4) goto exit;
//debugger view:
//expression: choice
//value: 1
The constant_dynamic_handler is a lambda function declared earlier, that just changes choice to some integer other than 0. The fact that I can pause in the loop means that the loop is not exited, but the value is in fact changed. I cannot step over one step in the debugger as it will fail to read the memory on the CPU and requires a restart to debug again.
choice is declared simply in the same scope as the if-statement block, as int choice = 0;. It is altered only within an interrupt listener triggered with a hardware input.
The program works with O0 flag instead of O1 or O2.
I'm using NXP K60 and c++11, if that is required. Is it my problem? Could there be any thing that I'm not aware of? I am a beginner at MCU programming, and this code works on desktop(Just tried, doesn't work).
    \$\begingroup\$ Have you compiled it with optimizations on your desktop? \$\endgroup\$
    – Arsenal
    Jul 23, 2018 at 8:08
  • 26
    \$\begingroup\$ I wouldn't expect this to work on a desktop system either. C compilers are allowed to read a variable once, and then assume it doesn't change, unless it's declared volatile. Every compiler I've used in the last 20 years performs this optimisation. \$\endgroup\$
    – Jules
    Jul 23, 2018 at 8:18
  • 7
    \$\begingroup\$ Others have already pointed out the reason why this doesn't work with -O2. I'd also recommend (as a matter of style) simplifying the loop - why loop forever, and then break when a condition is met, rather than just doing while (choice == 0) {} ? \$\endgroup\$
    – psmears
    Jul 23, 2018 at 9:52
  • 33
    \$\begingroup\$ Post code, not images of code. \$\endgroup\$
    – OmarL
    Jul 23, 2018 at 10:30
  • 6
    \$\begingroup\$ How is choice declared? \$\endgroup\$
    – OmarL
13
(Cross site duplicate on SO about the thread case, rather than interrupt/signal-handler case). Also related: When to use volatile with multi threading?
A data race on a non-atomic variable1 is Undefined Behaviour in C++112. i.e. potentially-concurrent read+write or write+write without any synchronization to provide a happens-before relationship, e.g. a mutex or release/acquire synchronization.
The compiler is allowed to assume that no other thread has modified choice between two reads of it (because that would be data-race UB (Undefined Behaviour)), so it can CSE and hoist the check out of the loop.
This is in fact what gcc does (and most other compilers too):
while(!choice){}
optimizes into asm that looks like this:
if(!choice)     // conditional branch outside the loop to skip it
    while(1){}  // infinite loop, like ARM  .L2: b .L2
This happens in the target-independent part of gcc, so it applies to all architectures.
You want the compiler to be able to do this kind of optimization, because real code contains stuff like for (int i=0 ; i < global_size ; i++ ) { ... }. You want the compiler to be able to load the global outside the loop, not keep re-loading it every loop iteration, or for every access later in a function. Data has to be in registers for the CPU to work with it, not memory.
The compiler could even assume the code is never reached with choice == 0, because an infinite loop with no side effects is Undefined Behaviour. (Reads / writes of non-volatile variables don't count as side effects). Stuff like printf is a side-effect, but calling a non-inline function would also stop the compiler from optimizing away the re-reads of choice, unless it was static int choice. (Then the compiler would know that printf couldn't modify it, unless something in this compilation unit passed &choice to a non-inline function. i.e. escape analysis might allow the compiler to prove that static int choice couldn't be modified by a call to an "unknown" non-inline function.)
In practice real compilers don't optimize away simple infinite loops, they assume (as a quality-of-implementation issue or something) that you meant to write while(42){}. But an example in https://en.cppreference.com/w/cpp/language/ub shows that clang will optimize away an infinite loop if there was code with no side effects in it which it optimized away.
Officially supported 100% portable / legal C++11 ways to do this:
You don't really have multiple threads, you have an interrupt handler. In C++11 terms, that's exactly like a signal handler: it can run asynchronously with your main program, but on the same core.
C and C++ have had a solution for that for a long time: volatile sig_atomic_t is guaranteed to be ok to write in a signal handler and read in your main program
An integer type which can be accessed as an atomic entity even in the presence of asynchronous interrupts made by signals.
void reader() {
    volatile sig_atomic_t shared_choice;
    auto handler = a lambda that sets shared_choice;
    ... register lambda as interrupt handler
    sig_atomic_t choice;        // non-volatile local to read it into
    while((choice=shared_choice) == 0){
        // if your CPU has any kind of power-saving instruction like x86 pause, do it here.
        // or a sleep-until-next-interrupt like x86 hlt
    ... unregister it.
    switch(choice) {
        case 1: goto constant;
        case 0: // you could build the loop around this switch instead of a separate spinloop
                // but it doesn't matter much
Other volatile types are not guaranteed by the standard to be atomic (although in practice they are up to at least pointer width on normal architectures like x86 and ARM, because locals will be naturally aligned. uint8_t is a single byte, and modern ISAs can atomically store a byte without a read/modify/write of the surrounding word, despite any misinformation you may have heard about word-oriented CPUs).
What you'd really like is a way to make a specific access volatile, instead of needing a separate variable. You might be able to do that with *(volatile sig_atomic_t*)&choice, like the Linux kernel's ACCESS_ONCE macro, but Linux compiles with strict-aliasing disabled to make that kind of thing safe. I think in practice that would work on gcc/clang, but I think it's not strictly legal C++.
With std::atomic<T> for lock-free T
(with std::memory_order_relaxed to get efficient asm without barrier instructions, like you can get from volatile)
C++11 introduce a standard mechanism to handle the case where one thread reads a variable while another thread (or signal handler) writes it.
It provides control over memory-ordering, with sequential-consistency by default, which is expensive and not needed for your case. std::memory_order_relaxed atomic loads/stores will compile to the same asm (for your K60 ARM Cortex-M4 CPU) as volatile uint8_t, with the advantage of letting you use a uint8_t instead of whatever width sig_atomic_t is, while still avoiding even a hint of C++11 data race UB.
(Of course it's only portable to platforms where atomic<T> is lock-free for your T; otherwise async access from the main program and an interrupt handler can deadlock. C++ implementations aren't allowed to invent writes to surrounding objects, so if they have uint8_t at all, it should be lock-free atomic. Or just use unsigned char. But for types too wide to be naturally atomic, atomic<T> will use a hidden lock. With regular code unable to ever wake up and release a lock while the only CPU core is stuck in an interrupt handler, you're screwed if a signal/interrupt arrives while that lock is held.)
#include <atomic>
#include <stdint.h>
volatile uint8_t v;
std::atomic<uint8_t> a;
void a_reader() {
    while (a.load(std::memory_order_relaxed) == 0) {}
    // std::atomic_signal_fence(std::memory_order_acquire); // optional
void v_reader() {
    while (v == 0) {}
Both compile to the same asm, with gcc7.2 -O3 for ARM, on the Godbolt compiler explorer
a_reader():
    ldr     r2, .L7      @ load the address of the global
.L2:                     @ do {
    ldrb    r3, [r2]        @ zero_extendqisi2
    cmp     r3, #0
    beq     .L2          @ }while(choice eq 0)
    bx      lr
.L7:
    .word   .LANCHOR0
void v_writer() {
    v = 1;
void a_writer() {
    // a = 1;  // seq_cst needs a DMB, or x86 xchg or mfence
    a.store(1, std::memory_order_relaxed);
ARM asm for both:
    ldr     r3, .L15
    movs    r2, #1
    strb    r2, [r3, #1]
    bx      lr
So in this case for this implementation, volatile can do the same thing as std::atomic. On some platforms, volatile might imply using special instructions necessary for accessing memory-mapped I/O registers. (I'm not aware of any platforms like that, and it's not the case on ARM. But that's one feature of volatile you definitely don't want).
With atomic, you can even block compile-time reordering with respect to non-atomic variables, with no extra runtime cost if you're careful.
Don't use .load(mo_acquire), that will make asm that's safe with respect to other threads running on other cores at the same time. Instead, use relaxed loads/stores and use atomic_signal_fence (not thread_fence) after a relaxed load, or before a relaxed store, to get acquire or release ordering.
A possible use-case would be an interrupt handler that writes a small buffer and then sets an atomic flag to indicate that it's ready. Or an atomic index to specify which of a set of buffers.
Note that if the interrupt handler can run again while the main code is still reading the buffer, you have data race UB (and an actual bug on real hardware) In pure C++ where there are no timing restrictions or guarantees, you might have theoretical potential UB (which the compiler should assume never happens).
But it's only UB if it actually happens at runtime; If your embedded system has realtime guarantees then you may be able to guarantee that the reader can always finish checking the flag and reading the non-atomic data before the interrupt can fire again, even in the worst-case where some other interrupt comes in and delays things. You might need some kind of memory barrier to make sure the compiler doesn't optimize by continuing to reference the buffer, instead of whatever other object you read the buffer into. The compiler doesn't understand that UB-avoidance requires reading the buffer once right away, unless you tell it that somehow. (Something like GNU C asm("":::"memory") should do the trick, or even asm(""::"m"(shared_buffer[0]):"memory")).
Of course, read/modify/write operations like a++ will compile differently from v++, to a thread-safe atomic RMW, using an LL/SC retry loop, or an x86 lock add [mem], 1. The volatile version will compile to a load, then a separate store. You can express this with atomics like:
uint8_t non_atomic_inc() {
    auto tmp = a.load(std::memory_order_relaxed);
    uint8_t old_val = tmp;
    tmp++;
    a.store(tmp, std::memory_order_relaxed);
    return old_val;
If you actually want to increment choice in memory ever, you might consider volatile to avoid syntax pain if that's what you want instead of actual atomic increments. But remember that every access to a volatile or atomic is an extra load or store, so you should really just choose when to read it into a non-atomic / non-volatile local.
Compilers don't currently optimize atomics, but the standard allows it in cases that are safe unless you use volatile atomic<uint8_t> choice.
Again what we're really like is atomic access while the interrupt handler is registered, then normal access.
C++20 provides this with std::atomic_ref<>
But neither gcc nor clang actually support this in their standard library yet (libstdc++ or libc++). no member named 'atomic_ref' in namespace 'std', with gcc and clang -std=gnu++2a. There shouldn't be a problem actually implementing it, though; GNU C builtins like __atomic_load work on regular objects, so atomicity is on a per-access basis rather than a per-object basis.
void reader(){
    uint8_t choice;
    {  // limited scope for the atomic reference
       std::atomic_ref<uint8_t> atomic_choice(choice);
       auto choice_setter = [&atomic_choice] (int x) { atomic_choice = x; };
       ui::Context::addEventListener(ui::EventType::JOYSTICK_DOWN, &choice_setter);
       while(!atomic_choice) {}
       ui::Context::removeEventListener(ui::EventType::JOYSTICK_DOWN, &choice_setter);
    switch(choice) { // then it's a normal non-atomic / non-volatile variable
You probably end up with one extra load of the variable vs. while(!(choice = shared_choice)) ;, but if you're calling a function between the spinloop and when you use it, it's probably easier not to force the compiler to record the last read result in another local (which it may have to spill). Or I guess after the deregister you could do a final choice = shared_choice; to make it possible for the compiler to keep choice in a register only, and re-read the atomic or volatile.
Footnote 1: volatile
Even data-races on volatile are technically UB, but in that case the behaviour you get in practice on real implementations is useful, and normally identical to atomic with memory_order_relaxed, if you avoid atomic read-modify-write operations.
When to use volatile with multi threading? explains in more detail for the multi-core case: basically never, use std::atomic instead (with memory_order relaxed).
Compiler-generated code that loads or stores uint8_t is atomic on your ARM CPU. Read/modify/write like choice++ would not be an atomic RMW on volatile uint8_t choice, just an atomic load, then a later atomic store which could step on other atomic stores.
Footnote 2: C++03:
Before C++11 the ISO C++ standard didn't say anything about threads, but older compilers worked the same way; C++11 basically just made it official that the way compilers already work is correct, applying the as-if rule to preserve the behaviour of a single thread only unless you use special language features.
    \$\begingroup\$ Re: "volatile might imply using special instructions necessary for accessing memory-mapped I/O registers." - It does on the Xtensa ISA of, e.g., those ESP-8266 chips: The docs say the compiler should insert the MEMW ("memory wait") instruction before reads and after writes to volatile variables to make sure the data has propagated through any/all pipelines or caches. IIRC, there was also a known silicon bug where multiple writes to the same memory location in quick succession (w/o MEMW) could cause earlier writes to be skipped and only propagate the later writes to off-core hardware/memory. \$\endgroup\$
    – JimmyB
    Apr 10, 2019 at 11:51
55
The code optimizer has analyzed the code and from what it can see the value of choice will never change. And since it will never change, there's no point in checking it in the first place.
The fix is to declare the variable volatile so that the compiler is forced to emit code that checks its value regardless of the optimization level used.
  • 16
    \$\begingroup\$ I once ran across an embedded compiler that ignored volatile when you turned the optimiser on.... Oh how we laughed, it took ages to find and we would up grovelling thru the assembly output. All variables that are modified outside the normal control flow should be declared volatile, and yes, "volatile const" is a thing! \$\endgroup\$
    – Dan Mills
    Jul 23, 2018 at 9:58
  • 8
    \$\begingroup\$ In modern C++, std::atomic<uint8_t> choice would be good for communication between an interrupt handler and other code. Use choice.store(value, std::memory_order_relaxed), and in this loop uint8_t tmp; while(0 == (tmp=choice.load(std::memory_order_relaxed)) {} would be good. (And probably compile to the same asm as volatile) \$\endgroup\$ Jul 23, 2018 at 14:06
  • 6
    \$\begingroup\$ @PeterCordes: using std::atomic<uint8_t> will very likely produce different assembly compared to volatile (unless you're using that weird MSVC extension, which IIRC only works for x86, x64 and possibly ARM). Atomics need to update the value atomically, i.e. no observer should be able to see any intermediate state. OTOH volatile only says "this value might have changed since you last read it", which is much less restrictive. Also, on some platforms there are special instructions for some special volatile values, e.g. memory mapped registers. \$\endgroup\$
    – hoffmale
    Jul 23, 2018 at 18:28
  • 6
    \$\begingroup\$ @DanielCheung: A data race on a non-atomic variable is Undefined Behaviour in C++11 (concurrent read+write), which is why the compiler is allowed to convert while(!choice){} into if(!choice) infloop();, i.e. to hoist the load out of the loop. Lots of code repeatedly references the same global variable within a function, and forcing C++11 compilers to de-optimize it would suck a lot. \$\endgroup\$ Jul 23, 2018 at 20:27
  • 5
    \$\begingroup\$ @PeterCordes An infinate loop with no side effects is Undefined Behaviour. en.cppreference.com/w/cpp/language/ub As such the compiler is allowed to optimise further if it wants, and just simply remove it entirely. \$\endgroup\$
    – UKMonkey
    Jul 24, 2018 at 9:18
