Good morning all. I am implementing a subcircuit in LTspice, and I want also to modify the plot.defs to calculate some quantities with the voltages/currents inside the subcircuit. Thus, I will have a function like:
.func A(x) V(x:Vo)/V(x:Vin)
where the function "A" should take the instance name of the subcircuit as parameter, in order to access to its nodes (labelled Vo and Vin in the subcircuit, using a behavioral voltage source to make the node name always the same).
The syntax written above doesn't work, I get the error:
undefined symbol in: "A(<>)"
Where of course "X1" is the name given by spice to the instance of my subcircuit. What could be the problem? Please note that by explicitly writing the expression of "A" in the plot panel, everything works fine, so it is a matter of how to pass the instance name as parameter.
Thanks all in advance!
