Currently we are using the following power supply scheme: block diagram of power supply system This solution effectively separates the analog sub-part of the PCB from the noise of the digital sub-part.
Now we are going to use the following scheme: block diagram of power supply with ferrite beads instead of LDOs
The main benefit is decreasing the BOM cost. But would it separate the digital and analog sub-parts of the PCB?
LDOs are low noise parts (LP2980AIM5-3.3). The digital load - 20mA. The analog load - 10mA
  • \$\begingroup\$ It depends on load current and frequency of load changes and Load regulation spec of LDO. We cannot answer without specs. for source and load capacitance and ESR etc. \$\endgroup\$ – Tony Stewart Sunnyskyguy EE75 Jul 24 '18 at 5:27
  • \$\begingroup\$ LDOs are Low noise (LP2980AIM5-3.3), digital load - 20mA, analog load - 10mA. \$\endgroup\$ – user3583807 Jul 24 '18 at 5:38
  • \$\begingroup\$ If the load is constant, then no noise, if the load spec is -5% @ 150mA, can we assume it is -0.5% at 15mA step load. test it. 3.3V/20mA is 115 Ohms average load, but assumes sufficiently large Cap \$\endgroup\$ – Tony Stewart Sunnyskyguy EE75 Jul 24 '18 at 6:05
  • \$\begingroup\$ The question is still irrelevant until the spectral load is defined. -1 \$\endgroup\$ – Tony Stewart Sunnyskyguy EE75 Aug 10 '18 at 4:06
17
Ferrite Beads and LDOs are typically solve two different kinds of noise problems, so very rarely will you be able to "replace" an LDO with only a Ferrite Bead.
LDO's ability to filter noise is typically characterized as Power Supply Ripple Rejection (PSRR) and most LDOs are generally good attenuating Low Frequencies, but due to their bandwidth limitations don't attenuate high frequencies very well, the 8.1.3.1 Power-Supply Rejection Ratio (PSRR) Section of the TPS7A87 LDO's Datasheet illustrates this well:
Power-Supply Rejection Ratio Diagram
If you look at the PSRR for LP2980-N, found on Figure 25 of its Datasheet (see below), you will see the LDO's PSRR starts rolling-off at around 1 kHz and at higher frequencies it is actually the Output Capacitor filtering noise (notice the improvement of the PSRR plot as they increase COUT)
LP2980 Power Supply Ripple Rejection (PSRR)
Ferrite Beads on the other hand are typically used as a High Frequency filter, since they are essentially in its most simple representation an Inductor with a Resistor in series, which is "Resistive" a low frequencies (meaning it won't filter noise out) and becomes "Inductive" at frequencies around and above 1 MHz, depending on the Ferrite Bead.
So depending on the noise you are trying to filter out, which would be the DC-DC Noise, and possibly other source of noise as well you might want to use an LDO, a Ferrite Bead or both - the first question you'd need to ask yourself is "What Frequencies do I want to attenuate?"
Here are some resources you might find helpful:
Note: If you want to use an LDO with good PSRR but are concerned on cost you might want to look at LP5907, it seems to have lower cost than LP2980-N, has better PSRR performance, and a fixed 3.3 V option.
EDIT:
Your choice will probably depend on the DC-DC Switching Frequency, for example:
1. If you have a DC-DC SMPS which is switching between 50~400 kHz and LDO might be sufficient with the appropriate amount of output capacitance (mind the LDO's stability).
2. If you have a DC-DC SMPS which can be switching between 50~1500 kHz you might want to do both, because the LDO's PSRR might have ran out and it is even possible the Output Capacitor's impedance is decreasing.
3. If you have a DC-DC that is switching at 2 MHz the Ferrite Bead might be enough, but keep in mind that the DC-DC SMPS has inherently a higher Noise Power Density at lower frequencies which might affect your system's performance.
My best guess for you: since you are talking about 10 mA and 20 mA loads I suspect your DC-DC is switching a lower (Sub-1 MHz) frequencies, in that case your best bet is an LDO (mind the PSRR vs Frequency), since a Ferrite bead is very likely just a "Resistor" at that point.
If I were you and the layout allowed for it, I would put both LDO and the Ferrite Bead and put an (unpopulated) 0 Ω resistor in Parallel with the LDO, so you could bypass it later if you want.
|improve this answer|||||
  • \$\begingroup\$ So, ferrite bead can replace LDO if we scared high frequencies which in general produced by most DC/DC regulators? \$\endgroup\$ – user3583807 Jul 24 '18 at 13:16
  • \$\begingroup\$ It depends, if you look at a DC-DC module like this: ti.com/product/TPS82740B the Switching Frequency can actually go from 50 kHz to around 1.5 MHz, and in that case you might actually want both. I will edit my response and add some more details. \$\endgroup\$ – Victor S Jul 24 '18 at 14:43
  • \$\begingroup\$ It's not just the DC-DC switching frequency that determines whether a ferrite bead will help you. The edges of the switching action have very high frequency content that will completely bypass your LDO and the inductor you're switching across. Only a Ferrite Bead could solve this. \$\endgroup\$ – jalalipop Aug 2 '18 at 15:23
  • \$\begingroup\$ Although there is a lot of interesting info here for new users, the task is to attenuate load regulation error from DC to the upper spectrum, all of which has not been defined, and Analog loads in 3.3V LDO's tend to be constant current and thus much greater impedance than any ferrite bead. So I'm not sure if any of this is relevant until the transient load spec is defined. So the credits are much greater than the merit. \$\endgroup\$ – Tony Stewart Sunnyskyguy EE75 Aug 10 '18 at 4:04
LDO provides some isolation which varies with frequency.
Ferrite beads provide some isolation which varies with frequency.
What isolation do you need? How does it vary with frequency?
Build it, and test it.
You might also want to try a ferrite bead to your digital parts, as they don't need such a precise VCC, and to stop fast edges getting back onto the power supply. Then use an LDO to your analogue parts.
