I have 2 checks which are similar, except by the range of the generate: All works OK, it looks like this:
check : for bit in (1 to 5)  generate
  process
          some cool stuff;
  end process;
end generate  check ;
check2 : for bit in (7 to 8)  generate
  process
          Same some cool stuff;
  end process;
end generate  check2 ;
I would like to implement something simpler to maintain like this:
check : for bit in (1 to 5) & (7 to 8)  generate
  process
          Simpler to mantain the cool stuff;
  end process;
Is this possible ??
  • 5
    \$\begingroup\$ In this case you could do a range of 1 to 8 and add an if not 6 \$\endgroup\$ – Oldfart Jul 24 '18 at 10:30
  • \$\begingroup\$ No. A for generate parameter specification is a single discrete range. A range consists of scalar bounds and a direction. \$\endgroup\$ – user8352 Jul 24 '18 at 11:17
  • \$\begingroup\$ Question apart, 'BIT' is datatype keyword ... So it can't be used as indexing for generate I guess. \$\endgroup\$ – Sourabh Tapas Jul 29 '18 at 5:09
  • \$\begingroup\$ The 'bit' parent byte/word etc must be named first. Bit cans must be named. \$\endgroup\$ – Sparky256 Aug 2 '18 at 0:11
You can define your range as an array and use the for-loop to run through this array:
type arr is array(0 to 7) of integer;
constant bit : arr := (0,1,2,3,4,5,7,8);
check : for i in 0 to 7 generate
   cool_stuff(bit(i));
end generate;
i followed the "oldfart" user sugestion , and did a range 1 to 8 and added an if not for 6...
There probably cleaner ways to do it , but it works..
i'm still interested in cleaner ways...
