I would like to simulate a verilog design that is to interface (via a FiFo to USB chip) with a program running on my computer. I have set up my program to redirect all reads and writes to Linux FiFo files (man mkfifo) and am now trying to write a testbench for my verilog code that emulates the FiFo to USB chip. The idea is to read data from the Linux FiFo file and -if there is any- forward it to my DUT.
The Verilog standard names a number of system tasks to read data from a file
- $fgetc (Get a byte)
- $fgets (Get a string)
- $fscanf (Get formatted data)
- $fread (Get binary data)
- $readmem* (Fill a whole memory at once)
However, these system tasks will block until there is data available or an error occurs. Even worse, they block the whole testbench even when fork'ed so something along the lines of
reg [8:0] code = 9'd0;
fork : fgetc_with_timeout
begin
code=$fgetc(input_file);
disable fgetc_with_timeout;
end
begin
#300;
end
join
if(code)
will not work. So, is there any way to get a nonblocking read from a file or is there a way to get the number of remaining bytes/bits/words in a file?
I am using Xilinx ISE so I am constrained to Verilog (not System Verilog), so I am looking for something that works in ISE, and I would prefer to not use PLI code for this if possible.
Best regards, mox
p.S.> Searching for anything involving 'nonblocking' and 'verilog' lists mostly results not related to my problem, however I have found this non-answered question at the Xilinx forums: https://forums.xilinx.com/t5/Simulation-and-Verification/xsim-and-Verilog-file-IO-is-non-blocking-read-of-a-file-possible/td-p/685611
