For an application I need to generate a 10 MHz sine wave signal that is modulated with 20 KHz triangle signal. This is going to be frequency modulated.
This goes into another circuit which require a low phase noise. What is my best option to generate this signal effectively with low noise and reasonable cost. So far I have seen DSS solutions from ADI.
closed as unclear what you're asking by Andy aka, laptop2d, Finbarr, Dmitry Grigoryev, duskwuff Jul 26 '18 at 21:09
Please clarify your specific problem or add additional details to highlight exactly what you need. As it's currently written, it’s hard to tell exactly what you're asking. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
    \$\begingroup\$ 20 kHz is the modulation frequency, or the peak deviation? \$\endgroup\$ – The Photon Jul 24 '18 at 15:18
    \$\begingroup\$ Modulating the 10 MHz by how much? What is the frequency deviation required? \$\endgroup\$ – The Photon Jul 24 '18 at 15:29
    \$\begingroup\$ This is hard work. Like watching paint dry! \$\endgroup\$ – Andy aka Jul 24 '18 at 15:37
    \$\begingroup\$ You are modulating the frequency with a 20 kHz triangle wave. You could be modulating it between 9.99 MHz and 10.01 MHz, or between 2 MHz and 18 MHz. Some solutions might work for one but not the other. (Another word for this is modulation index). \$\endgroup\$ – The Photon Jul 24 '18 at 23:15
    \$\begingroup\$ 10 MHz seems like an inconveniently low frequency (in terms of required antenna size) to do that kind of thing at. And unless you live in Somalia or someplace, a band that's likely to be cluttered with lots of licensed users who might notice your experiments. \$\endgroup\$ – The Photon Jul 25 '18 at 1:01
Solutions that come to mind:
  • Microcontroller + DAC: The use of DSP / DDS (direct digital synthesis) techniques on a fast microcontroller (preferably with an integrated FPU) to generate a frequency modulated sine wave could be a viable/inexpensive solution, with an internal or external (parallel) DAC, and an accurate external clock source. - A 10 MHz (carrier) and a 20 kHz modulation signal could probably be generated with a microcontroller from the STM32F/H series (by ST). - Lookup tables, ARM DSP optimizations and fix point math could help. - Whether the result satisfies your application's requirements depends on the necessary quality of the signal (sampling rate/depth, aliasing effects, jitter etc.). - The signal quality could probably be improved with an external analog filter.
  • FPGA + DAC: The signal could be generated with an FPGA and digital-to-analog converted with a fast parallel DAC, all clocked from an accurate clock source. The sine wave/carrier and the modulation signal (triangle) can be generated right inside the FPGA. (Instead of using a lookup table, the CORDIC way of implementing a sine function could come in handy). This could probably already be accomplished with a small/inexpensive FPGA from the ICE40 series (by Lattice).
  • Specialized IC: The direct digital synthesis (DDS) chips by Analog Devices might be a good choice, like you've mentioned above (?). (But I've never worked with them myself yet, so I can't tell...) - Compared to the other solutions above, specialized ICs are black boxes, and your solution will strongly depend on the supply of a single manufacturer.
  • Analog cirucit: The whole thing could be done with analog techniques, but that's usually harder, in my experience. And it is probably more expensive/difficult to get reliable/stable results.
