I am working on an STM32F103RBT6 program and at some point I need to store values in the FLASH.
Writing in Flash is working as a charm, if I parse through the memory of my microcontroller, I see that the data has been written at the expected spot.
However, if I try to read the data I stored on a word (uint32_t), I read 0.
__attribute__((__section__(".nb_Frames"))) const uint32_t nb_Frames_Flash;
uint8_t CAN_nb_Frames_Tx_cc = 0;
CAN_nb_Frames_Tx_cc = (nb_Frames_Flash & 0x000000FF);
For example here, I want to get the low byte of the value stored in nb_Frames_Flash (0x01 for example), but CAN_nb_Frames_Tx_cc stays = 0.
I am sure that nb_Frames_Flash != 0 because If I go through these lines step by step thanks to the debugger, I can see that nb_Frames_Flash = 0x00010101
(which is the value I wrote in the Flash). The assignement just feels like it's not going through ...
I have tried to change the assignement : CAN_nb_Frames_Tx_cc = (nb_Frames_Flash & 0x000000FF);
by adding casts, changing the definition of CAN_nb_Frames_Tx_cc (uint32_t for instance), going through an intermediate variable ... But it just won't work ...
I am really stuck here and I don't know why it is not properly working.
The thing that makes me go nuts is that reading in Flash is completely working for structures. I stored structures in Flash, and I have no issue to read them and store them in a RAM variable ...
In advance, thank you for your help !
EDIT : Here is my linker script :
RAM (xrw) : ORIGIN = 0x20000000, LENGTH = 20K
FLASH (rx) : ORIGIN = 0x8000000, LENGTH = 128K - 5K
Erases (RW) : ORIGIN = 0x801EC00, LENGTH = 4
Frames (RW) : ORIGIN = 0x801EC04, LENGTH = 4
TRAMESTx (RW) : ORIGIN = 0x801EC08, LENGTH = 1400
TRAMESRx (RW) : ORIGIN = 0x801F180, LENGTH = 1800
TRAMESADC(RW) : ORIGIN = 0x801F888, LENGTH = 800
TRAMESOP (RW) : ORIGIN = 0x801FBA8, LENGTH = 800
/* Define output sections */
SECTIONS
/* The startup code goes first into FLASH */
.isr_vector :
. = ALIGN(4);
KEEP(*(.isr_vector)) /* Startup code */
. = ALIGN(4);
} >FLASH
.nb_Erases :
. = ALIGN(4);
*(.nb_Erases)
. = ALIGN(4);
} > Erases
.nb_Frames :
. = ALIGN(4);
*(.nb_Frames)
. = ALIGN(4);
} > Frames
.user_TramesTx :
. = ALIGN(4);
*(.user_TramesTx)
. = ALIGN(4);
} > TRAMESTx
.user_TramesRx :
. = ALIGN(4);
*(.user_TramesRx)
. = ALIGN(4);
} > TRAMESRx
.user_TramesADC :
. = ALIGN(4);
*(.user_TramesADC)
. = ALIGN(4);
} > TRAMESADC
.user_TramesOp :
. = ALIGN(4);
*(.user_TramesOp)
. = ALIGN(4);
} > TRAMESOP
