Which areas in flash memory are scanned during bootup to make sure that there is configuration file present in the external flash memory?
  • 6
    \$\begingroup\$ This is something your FPGA datasheet should tell. \$\endgroup\$ – Eugene Sh. Jul 25 '18 at 12:43
    \$\begingroup\$ Depends on the FPGA. What FPGA are you asking about? \$\endgroup\$ – crj11 Jul 25 '18 at 12:45
In general the FPGA does not know or care if the FPGA has a file present before it tries to load the configuration data. There is a CRC in the file that is checked at the end of configuration that the FPGA uses to determine if a valid configuration has been loaded. There is a signal called CONFIG_DONE that indicates if the configuration was successful.
    \$\begingroup\$ In general it does not actually start loading config data until it reads the correct header at the start of the config data. \$\endgroup\$ – crj11 Jul 25 '18 at 17:24
