I have this power entry module with a 6A rated current. The module needs two fuses to be installed. The exact model is:
FN 286B 6-06 and at the bottom of page 2 the rated current is given as 6A at 40°C and 7.2A at 25°C.
The data-sheet is not recommending the factor for the fuse current sizing and the type of the fuse. It only mentions the dimensions of the fuse.
I couldn't find consistent information about this. I thought a 10A slow fuse would be too big for this. What current rated fuse and type would be suitable roughly for this module? Is there a rule of thumb?
  • \$\begingroup\$ It depends on the load . If it’s a slow starting motor or large cap. bank use SloBlo otherwise not. \$\endgroup\$ – Tony Stewart Sunnyskyguy EE75 Jul 26 '18 at 14:46
  • \$\begingroup\$ You need to size the fuse for the weakest link (wire, PCB trace, connector pin, etc). \$\endgroup\$ – EE_socal Jul 26 '18 at 15:58
