-7
 constant <clock>_period : time := 10 ns;
What is the error with this code ? it says syntax error near "<".
    \$\begingroup\$ Using google I'd say: constant clk_period : time := 10 ns; would be correct \$\endgroup\$ – Alexander von Wernherr Jul 27 '18 at 8:49
    \$\begingroup\$ Why do you have the “<“ and “>”? \$\endgroup\$ – Blair Fonville Jul 27 '18 at 8:52
I think you generated a testbench-template in Vivado or ISE, as these programs generate code like this.
The idea is that you replace the <clock> with the name of your clock-signal: If your clock-signal is called clk, the line would become
which is perfectly fine.
VHDL names can contain the following:
  • letters
  • numbers
  • underscores
They are also case insensitive, have to start with a letter and cannot contain two adjacent underscores (From the Doulos Golden Reference Guide).
< and > are not a letter, number or an underscore.
  • \$\begingroup\$ Names are a larger subject, see IEEE Std 1076-2008 8. Names. You're describing a basic identifier, a lexical element see 15.4.2. There's also the extended identifier (15.4.3). extended_identifier ::= \ graphic_character { graphic_character } \ where a backslash can be represented in the sequence of graphic characters by escaping it with a preceding backslash. constant \<clock>_period\ : time := 10 ns; would be a legal declaration with the object name \<clock>_period\ . \$\endgroup\$ – user8352 Jul 27 '18 at 23:11
