Here I have the image of a signal in the output of U2, and the output is shown in green in the graph(sorry for the poor quality). Highest value = 3.3V, Lowest value = 0V, sine wave, 60 Hz. enter image description here
Now I have the same circuit but with that 1N4728 zener connected across and the output signal behaves like below: enter image description here
The zener is working under low current(about 24mA) as its main Izt is Izt= 76mA, so I expected to have a voltage less than 3v3 as spice has shown.
Yet, the real question is I don't get the fact the zener is being able to clamp the output voltage without a resistor in series with it. In my understanding the zener should face the whole sinusoidal wave since there's no resistor in series to share the remaining voltage with. I tried that on real circuits with TL082 OpAmp and the same happened. I've also checked the TL082 output resistance and it's about 0.01 Ohm in the 60Hz range(which is the frequency of my signal), so that would for sure not be the trouble.
So, what exactly is going on in this circuit? Shouldn't a zener have a series resistor in order to clamp correctly?
Thank you for any help.
Source: TL082 datasheet.
The absolute continuous ratings for the TL082 state that the output short-circuit duration is 'continuous'. This means that there is current limiting built in. The low output impedance you quoted is conditional on the output stage not being overloaded.
Looking at Figure 7 the positive current limit (applicable to your design) is 20 mA but temperature dependent. I would design for 10 mA maximum.
The lesson: you can't take one datasheet parameter in isolation.
  • \$\begingroup\$ It made my thoughts clearer now. I wouldn't see it so easily like you did in the datasheet, thank you very much. \$\endgroup\$ Jul 31, 2018 at 0:47
There are several things to consider as @Transistor points out and another consideration is this graph - how much output voltage swing you can get for a given load resistance: -
The graph above is an extract from the more modern combined TL081/2/4 data sheet. The earlier TL082 data sheet implies that with a 100 ohm load the output swing is 4 volts p-p but this is somewhat at odds with its output current source/sink graph.
As the zener voltage starts to be exceeded, the load resistance that it produces drops rapidly down to a few tens of ohms so, as per the graph above you would expect the voltage to become clamped at around the zener point. The output impedance assessment in your question I think is based on this: -
However, this is a "small signal" graph. I know it's not clearly stated that it is for small signals but it's something that you get used to seeing and understanding. It's a calculated graph based on the open-loop gain graph and the amount of gain a particular op-amp may be configured for.
  • \$\begingroup\$ Could I think of the situation as a dynamic output impedance being changed when the current begins to be limited by the opamp? And as a result this internal output impedance would behave like the ''series'' resistor or that's incorrect? \$\endgroup\$ Jul 31, 2018 at 0:51
  • \$\begingroup\$ The small signal output impedance is due to the op-amp open-loop gain not being infinite. There is a DC limit (usually of 100k to 1000k). When negative feedback is applied there is a small error due to O/L gain being finite and this error is made worse by loading because loading eats into the O/L gain and makes the error bigger - this translates to an equivalent output impedance. Not sure if this answers your comment? \$\endgroup\$
    Jul 31, 2018 at 9:00
  • \$\begingroup\$ Not sure yet. What exactly would be the loading in this case? The zener itself? Then due to this error, which is made greater since O/L gain is finite, the output impedance kind of "increases"? \$\endgroup\$ Aug 1, 2018 at 1:27
  • \$\begingroup\$ Even feedback resistors can be regarded as a load - anything that takes current from the output pin. If you have a simulator handy it's easy to simulate. \$\endgroup\$
    Aug 1, 2018 at 8:54
  • \$\begingroup\$ I guess I've gotten the idea. It has been clearer since the first comment up to now. From now and on I'll look a bit more carefully in the datasheet to understand it \$\endgroup\$ Aug 1, 2018 at 13:05
The closed loop output impedance in the linear region is chiefly due to OP Amp
Zout(f)=Rs/(gain(f)+1)
When the output clips due to internal current limit the loop becomes open , gain goes to 0 and Zout=Rs, the value of Vcc/Rs used for current sensing + Rce.
