I have bread boarded the following proteus proffessional project:
Air cooler circuit schematic
The idea is that the rotary switch controls the speed of the 2 DC fans, the high option results in 100% duty cycle, Med 75%, and Low is 50%. The tutorial I followed to configure the PWM module of the PIC16F877A gives this image taken from the IC's manual about how the PWM mode of the MCU basically works:
PMM operation of PIC16F877A
PWM Signal Generation: Once the PWM is configured and Timer2 is enabled, TMR2 starts incrementing depending on the prescalar. Once the TMR2 value is equal to dutyCycle(CCPR1L+CCP1CON<5:4>) the PWM pin will be pulled LOW. The timer still continues to increment till it matches with the period PR2. After which the PWM pin will be pulled HIGH and TMR2 is reset for next cycle. Source
And so I wrote some code in mikroC where I configure both CCP modules since I need a PWM signal to control the speed of two fans. Here is the snippet of code which is supposed to configure the PWM mode of these CCP registers:
TRISC.RC1 = 0;
TRISC.RC2 = 0;
CCP1CON = 0x0F;  // Select the PWM mode.
CCP2CON = 0x0F;
TMR2ON = 1;
PR2 = 100;      // Set the Cycle time to 100 for varying the duty cycle from 0-100
CCPR1L = 0;     // By default set the dutyCycle to 0
CCPR2L = 0;
When I run the simulation it works in proteus. When I try to upload it to the MCU using my Pick kit 3 I am not getting a PWM signal on PORTC1-2. I have checked that the switch is working using a multimeter and have probed the crystal and found that it is oscillating. The switching mechanism doesn't seem to have a notable effect on the signals on PORTC1-2 apart from maybe some slight glitch when the switch position changes.
Here is a screenshot of what the signal looks like where I am supposed to be getting a PWM wave (PORTC1).
PORTC1
PORTC2 looks the same. Like I said I have monitored the switching mechanism, probed the crystal and the PWM ports. I can't think why this won't work when it does in simulation. Maybe somebody could help me debug this. The rest of the C code is shown here:
    int solenoid_state = 0;
    void main()
        //TRISB = 0x0F;    // Configure PORTB
        TRISB.RB0 = 1;
        TRISB.RB1 = 1;
        TRISB.RB2 = 1;
        TRISB.RB3 = 1;
        TRISD.RD0 = 0;
        TRISD.RD1 = 0;
        TRISC.RC1 = 0;
        TRISC.RC2 = 0;
        CCP2CON = 0x0F;
        TMR2ON = 1;
                            cycle from 0-100
        CCPR2L = 0;
        //solenoid_state = 0;
        while(1){
                  if(RB0_bit == 0)                // Off state
                     delay_ms(300);
                     if(RB0_bit == 0)
                         CCPR1L = 0;
                         CCPR2L = 0;
                         RD0_bit = 0;
                         RD1_bit = 0;
       while(RB0_bit == 0)            //Do nothing until switch status changes
          else
             solenoid_state = 1;
             //RD0_bit = 1;
             //RD1_bit = 1;
          while(solenoid_state == 1)
             if(RB1_bit == 0)                 // Low state
                 delay_ms(300);
                 if(RB1_bit == 0)
                   CCPR1L = 50;
                   CCPR2L = 50;
                 while(RB1_bit == 0)            //Do nothing until switch status changes
         else if(RB2_bit == 0)            // Med state
             delay_ms(300);
             if(RB2_bit == 0)
                CCPR1L = 75;
                CCPR2L = 75;
         while(RB2_bit == 0)           //Do nothing until switch status changes
         else if(RB3_bit == 0)           // High state
             delay_ms(300);
             if(RB3_bit == 0)
                CCPR1L = 100;
                CCPR2L = 100;
          else
             //RD0_bit = 0;
             //RD1_bit = 0;
             solenoid_state = 0;
Any tips/hints appreciated,
Simon.
    \$\begingroup\$ I would take your CCPR1L and CCPR2L assignments and stick them in an area without conditions (such as right before your while loop) and comment everything else out to make sure the PWM itself is working. Then you know if you have a logic error or truly a PWM problem. \$\endgroup\$ – Los Frijoles Jul 31 '18 at 5:15
  • \$\begingroup\$ Have you set the configuration bits properly? Take special attention to the oscillator. \$\endgroup\$ – Bruno Ferreira Jul 31 '18 at 10:39
Others suspect that your problems with the real hardware lie in the part of your code that MikroC makes very hard for you to show to others.
There are the settings for the PIC configuration words and the start up initialization of the Analog to Digital Converter and Comparator function blocks.
For simple projects like the one described it is handy to disable the ADC and Comparator functions then set or clear all of the bits in the configuration words to sensible values.
Here is your code changed to compile with the free XC8 compiler from Microchip:
 * file: main.c
 * target: PIC16F877A
 * compiler: XC8 v1.45
 * description:
 *  Configure for PWM output ib CCP1 and CCP2.
 *  Selector inputs from RB0, RB1, RB2, RB3.
#include <xc.h>
#pragma config FOSC = HS        // Oscillator Selection bits (HS oscillator)
#pragma config WDTE = OFF       // Watchdog Timer Enable bit (WDT disabled)
#pragma config PWRTE = OFF      // Power-up Timer Enable bit (PWRT disabled)
#pragma config BOREN = ON       // Brown-out Reset Enable bit (BOR enabled)
#pragma config LVP = OFF        // Low-Voltage (Single-Supply) In-Circuit Serial Programming Enable bit (RB3 is digital I/O, HV on MCLR must be used for programming)
#pragma config CPD = OFF        // Data EEPROM Memory Code Protection bit (Data EEPROM code protection off)
#pragma config WRT = OFF        // Flash Program Memory Write Enable bits (Write protection off; all program memory may be written to by EECON control)
#pragma config CP = OFF         // Flash Program Memory Code Protection bit (Code protection off)
#define _XTAL_FREQ 20000000
void main()
    INTCON = 0;         // disable interrupts
    ADCON1 = 0x06;      // disable ADC
    CMCON  = 0x07;      // disable Comparators
    TRISBbits.TRISB0 = 1;
    TRISBbits.TRISB1 = 1;
    TRISBbits.TRISB2 = 1;
    TRISBbits.TRISB3 = 1;
    TRISDbits.TRISD0 = 0;
    TRISDbits.TRISD1 = 0;
    TRISCbits.TRISC1 = 0;
    TRISCbits.TRISC2 = 0;
    CCP2CON = 0x0F;
    T2CON   = 0x01;     // Set TIMER2 prescale as 1:4
    TMR2ON = 1;
    PR2 = 99;           // Set the Cycle time to 100 for varying the duty cycle from 0-100
    CCPR2L = 0;
    solenoid_state = 0;
    while(1)
        if(PORTBbits.RB0 == 0)              // Off state
            __delay_ms(300);
                CCPR1L = 0;
                CCPR2L = 0;
                PORTDbits.RD0 = 0;
                PORTDbits.RD1 = 0;
            while(PORTBbits.RB0 == 0)       //Do nothing until switch status changes
        else
            solenoid_state = 1;
            //PORTDbits.RD0 = 1;
            //PORTDbits.RD1 = 1;
            if(PORTBbits.RB1 == 0)          // Low state
                __delay_ms(300);
                    CCPR1L = 50;
                    CCPR2L = 50;
                while(PORTBbits.RB1 == 0)   //Do nothing until switch status changes
            else if(PORTBbits.RB2 == 0)     // Med state
                __delay_ms(300);
                    CCPR1L = 75;
                    CCPR2L = 75;
                while(PORTBbits.RB2 == 0)   //Do nothing until switch status changes
            else if(PORTBbits.RB3 == 0)     // High state
                __delay_ms(300);
                    CCPR1L = 100;
                    CCPR2L = 100;
            else
                //PORTDbits.RD0 = 0;
                //PORTDbits.RD1 = 0;
                solenoid_state = 0;
Perhaps all your code needs are these lines:
  • \$\begingroup\$ The problem was actually just the writing to the T2CON register. I just needed to send a byte to this register to properly configure the prescale and the post scale bits. I will post the solution later only now I have another problem where the PWM signal on the CCP1-2 pins is only 0.5 Volts-not enough to switch on the FETS. It should be at least 3.8V. No idea what is causing this problem. \$\endgroup\$ – burton01 Aug 2 '18 at 2:41
  • \$\begingroup\$ Most often this is some kind of circuit wiring error, next are blown FETs, lastly blown PIC outputs. Without the PIC in the circuit how much current does it take to actually drive the FET gate input to 5.0 volts? \$\endgroup\$ – Dan1138 Aug 2 '18 at 3:34
    \$\begingroup\$ This was a problem caused by the probe. It was a 10:1 probe and so the voltage on this pin was 5V all along. \$\endgroup\$ – burton01 Aug 30 '18 at 6:18
