I need a 25mm x 30mm 120V 200 watt band heater.
Unfortunately, the only 25mm x 30mm 120V band heaters I have found are 300 watt.
What sort of circuit could I construct or purchase that could regulate the current flowing through a large heating element like that?
Ideally looking for something off the shelf.
I'm used to limiting current (say, through an LED) with a small resistor. I have no clue how to design for something high current like this.
Doesn't have to be adjustable, literally all I want to do is ensure the heating element dissipates 200 watts, not 300. I'm guessing the element is resistive.
My power supply is 250 watts, so I'm not trying to dissipate any power in the control circuit.
  • \$\begingroup\$ Why do you need it to be 200 watts? Current limitations, or 200 watts is the heat output you want? \$\endgroup\$
    – piojo
    Commented Jul 31, 2018 at 7:57
  • \$\begingroup\$ The project spec calls for 200 watts, and in addition my power supply is only 250 watts. I suppose I could try going lower, maybe experimenting with 100 watts. \$\endgroup\$
    – cat pants
    Commented Jul 31, 2018 at 7:59
  • \$\begingroup\$ Is this DC or AC? Because for AC you have tons of voltage regulators for just a few bucks \$\endgroup\$
    – Maple
    Commented Jul 31, 2018 at 8:19
    \$\begingroup\$ if you can reduce the voltage to 98V you'll get 200W power through the heater is your 120V AC or DC \$\endgroup\$ Commented Jul 31, 2018 at 8:38
4 Answers 4
AC: use a lamp dimmer
If your power source happens to be somewhere in the range of normal grid voltage and AC:
A resistive heater is indistiguishable from an incandescent light bulb (if you close your eyes).
So, a dimmer for halogen lamps will work. (internally, that's a phase-fired controller, but really, for your purposes: it only turns on the heaters for a percentage of time).
They can be had for a couple of € at furniture stores and construction / home improvement stores.
DC: follow piojo's advice
... and just use PWM with a MOSFET as switch (no need for overly large flyback protection diodes, can probably use one with an integrated one), setting your duty cycle to whatever makes the device output what you need.
There's ready-to-use PWM controllers for that, including FET gate drivers.
  • \$\begingroup\$ It's worth noting that a resistive dimmer won't dissipate the power where the OP wants it, unless the dimmer is put in the correct place (and can handle the heat). It's essentially the same as what I suggested with the power resistors, but perhaps easier to buy. \$\endgroup\$
    – piojo
    Commented Jul 31, 2018 at 8:42
    \$\begingroup\$ Never saw a resistive dimmer! All I know are thyristor / triac-based. \$\endgroup\$ Commented Jul 31, 2018 at 8:43
  • \$\begingroup\$ Oh, I was a kid when I learned about dimmers. I must never have updated my assumptions. Thanks for pointing that out! \$\endgroup\$
    – piojo
    Commented Jul 31, 2018 at 8:52
    \$\begingroup\$ @MarcusMüller You never worked in a theatre. Used to be bloody great linear rheostats to dim the spots. \$\endgroup\$
    – Henry Crun
    Commented Jul 31, 2018 at 11:42
  • \$\begingroup\$ Dimmer sounds perfect! I can just measure the current and slowly change the wiper position, then either hot glue the wiper in place, or mark with sharpie. Leaving margin of error of course. \$\endgroup\$
    – cat pants
    Commented Jul 31, 2018 at 22:08
You can't get the power down to 200 W with resistors unless those resistors can handle their share of the power. In other words, the resistors would need to be more heaters. If your heaters are 300 W, putting two in series would double the resistance and halve the power.
Or you can find another resistor (a power resistor or heater) which will bring you to exactly the power you need: at 120 V, your target current will be 1.66 A. The resistance that will give you this is 72 Ω. Your current heater is 48 Ω, if the given wattage is accurate. So you need to add an extra 24 Ω of resistors/heaters that can handle 1.66 A. The power will be I²*R, and if you split it over two resistors, metal power resistors should be able to handle that.
Another way to arrive at the exact power output you need is to cut out part of the waveform with a solid state AC dimmer (I think something based on a triac). The peak current output will still correspond to a higher power than your power source is rated for, but the average power can be tuned to be the power you want.
I'm not sure whether AC can be dimmed with PWM, but if so, that's also an option analogous to using the triac.
Assuming you mean 120 VAC, there are two simple ways to reduce power.
  • A phase-control device such as a light dimmer can easily handle 200 W, but calibrating to exactly that power might be an issue, as is insuring that in the event of failure of the control, power would never exceed 200 W.
  • A transformer can be used to buck the AC line voltage down to 98 VAC. The 300 W heater has a warm resistance of 48 ohms, so would dissipate ~200 W at the reduced voltage. Since the cold resistance might be a trifle less, it would initially draw more current, so a 3 amp secondary rating should be safe. For example, either Hammond 167M20, which is rated 20 VAC @ 3 A, or Hammond 166M24-BULK, at 24 VAC @ 3 A, would probably be within your required tolerance. Be careful to check the output voltage, first open circuit, to be sure the secondary is phased to buck line voltage, and under load, to be sure it's close to 98 VAC to the heater.
Bucking transformer, 120 VAC to 98 VAC
Phase control is easy to implement and uses a small device, but needs calibration and might go out of adjustment, while the transformer is heavy and bulky, but reliable.
N.B. In any case, use a thermal fuse to prevent overheating.
150W is probably close enough. Just use a diode.
