What is the simplest and best device (or circuit) to stop the flow of current in a 3.7V (2A) line when current in another 5V (2A) line is present?
Basically I want to make an UPS using a LiPo battery for a SIM800l, I have an SIM800l module attached to A 3.7V wall adapter but I also have connected the SIM800l to a 3.7V LiPo Battery, I want to stop using the battery when there is current from the USB wall charger.
I do not want to use a standard powerbank since these always use the battery.
  • \$\begingroup\$ An electromagnetic relay. \$\endgroup\$
    Jul 31, 2018 at 16:05
    \$\begingroup\$ That depends on just what your requirements are. Are these two lines feeding the same thing? Or are they isolated? \$\endgroup\$
    – Hearth
  • \$\begingroup\$ What is the application? There are chips that could do this. \$\endgroup\$ Jul 31, 2018 at 16:06
    \$\begingroup\$ Are you sure this is not another case of XY? Because the mentioned values hint strongly at switching between an adapter/USB and battery. Which is usually done by voltage, not current. i.e. the X problem would be: a way to disconnect the output line when voltage on the input line is present. \$\endgroup\$
    – Maple
    Jul 31, 2018 at 16:29
You can use a basic diode switch like this:
When 5 V is present, no current will flow from the 3.7 V source.
    \$\begingroup\$ 0.6 volts (the drop across the active forward-bias diode) out of 3.7v (or outa 5v) is a significant portion. you might have to accept 15% power loss or, at best, 85% efficiency. \$\endgroup\$ Jul 31, 2018 at 21:26
  • \$\begingroup\$ @Robert The O.P. wanted teh simplest [sic]. A 15% hit on efficiency is a fair price for simplicity in many cases. \$\endgroup\$ Aug 1, 2018 at 15:59
