I have an ESP-07 with NodeMCU firmware connected to a dimming module with a zero-crossing pin.
The current frequency should be 50Hz, which means that the time between two zero crossing should be 10ms, ~10000 microseconds.
However the time between two interrupts is sometimes correct, but often is about ~450 microseconds.
What's the catch? I use tmr to measure time
Here is the code:
gpio.mode(2, gpio.INPUT)
gpio.mode(5, gpio.OUTPUT)
t = tmr.now();
counter = 0;
local function zc_callback(level, pulse)
    counter = counter + 1;
    counter = counter % 200;
    if(counter == 1) then
        print(tmr.now() - t);
    end
    t = tmr.now();
end
gpio.trig(2, "up", zc_callback)
Thank you, I try to figure this for some time, it affects my light bulbs which blink instead of dimming.
  • \$\begingroup\$ How long is your print going to take? Will everything wait until the print is finished? \$\endgroup\$ – Transistor Aug 1 '18 at 20:31
  • \$\begingroup\$ I don't think it should matter because the time is measured before printing \$\endgroup\$ – Mihai Ionuţ-Cosmin Aug 1 '18 at 20:42
  • \$\begingroup\$ But you're calling it every 10 ms if it's in the interrupt. Try taking it out. \$\endgroup\$ – Transistor Aug 1 '18 at 21:30
  • \$\begingroup\$ I think you may also be forgetting to disable the interrupt on entry and re-enable on the way out. Won't that allow it to retrigger if the print routine isn't finished? \$\endgroup\$ – Transistor Aug 1 '18 at 21:38
    \$\begingroup\$ Do you have an oscilloscope? Have you used it to look at the zero-cross signal to check for noise? \$\endgroup\$ – brhans Aug 1 '18 at 21:55
-1
Ok, I got this, the mistake was the "up", "high" is what I need.
| improve this answer | |
    \$\begingroup\$ Thanks for closing this question. You can accept your own answer to mark it solved. \$\endgroup\$ – Transistor Aug 15 '18 at 19:26
