I am working on avr controllers for a while, but I have problem with "progisp" avr programming software. When I buy a new micro-controller like atmega32 it can be programmed properly for a while but after some days, suddenly when I want to reprogram it, Progisp shows the error "Chip Enable Program Error". I use USB programmer. For better understanding here is an image of progisp software.
progisp software error
I have searched the internet a lot to find a solution but there wasn't a proper and useful solution for my problem. I am sure that my micro-controllers are fine and not damaged because they work as they programmed but I am unable to reprogram them. I really thank you if you have any solution to help me.
And here is schematic diagram and real picture of my USB programmer.
  • \$\begingroup\$ Given that this will be a hardware issue, not a software issue, we will need a lot more information from you before we can help. e.g. schematic, pictures of hardware, what steps you have tried, etc. \$\endgroup\$ Aug 2, 2018 at 7:49
  • \$\begingroup\$ What is your USB programmer? How does the wiring look like? \$\endgroup\$
    – filo
    Aug 2, 2018 at 8:18
  • \$\begingroup\$ I have added schematic diagram and picture of USB programmer. i have searched the internet for a while, Someone said that you may accidentally programmed clock fuse bits as external clock or oscillator but it could be true because when i plug them without any external oscillator it works as it has been programmed. \$\endgroup\$
    – Linosa
    Aug 2, 2018 at 10:11
  • \$\begingroup\$ I always program high fuse bits and low fuse bits as oxD9E4 and all lock bits all equal to 1 and that are disabled. \$\endgroup\$
    – Linosa
    Aug 2, 2018 at 10:21
  • \$\begingroup\$ Did you happen to configure the reset pin as an input or an output? \$\endgroup\$
    – Dampmaskin
    Aug 2, 2018 at 12:09
I had this error before when I changed the clock fuse bits and set at external RC Oscillator, maybe you have the same problem. use a resistor and capacitor and build an external oscillator for your clock source and reprogram your micro.maybe it is work.
  • \$\begingroup\$ But you mean that you have set the fuse bits as external clock oscillator? If so i haven't do that. And as i said above they have been set as internal oscillator. \$\endgroup\$
    – Linosa
    Aug 2, 2018 at 10:14
