See next post in this series here adding a fet
All,
Here is a picture of an LTSpice simulation of a very basic MC34063 step up circuit which is behaving exactly as it should, 5V in 9V out.
I'm trying to adapt this one step at a time until I end up with a circuit featuring multiple isolated outputs with an overall current rated higher than the 1.5A of the MC34063. My next step is to add an external BJT which I've done here :
The real change, aside from the BJT, is that the inductor is now taken out of the MC34063 Switch Collector input, because the collector of the chip is only used to fire the BJT.. and the Inductor is now in the collector of the BJT, so it can get more current.
But as you can see, the output of this circuit gives me 5V ish. The switch is firing as you can see from the ripple.
What obvious thing am I missing here?
EDITS :
After changing to NPN transistor and increasing the load a little, I get this. It seems this particular transistor can sink some 300mA before it has a wobble. Next step is to add the FET. When I get that working I'll post it here because I've seen nowhere on the internet in which a full MC34063 step up of this kind is properly documented.
Thank you everyone for helping me.
Adding models used, I have no idea where I got these from. I downloaded many, this is the only one that works for step-up.
MC34063X.lib (place it in your lib/sub folder)
*========================================================== * MC34063 * ON Semiconductor * DC-DC controller * * This model was developed for ON Semiconductor by: * AEI Systems, LLC * 5777 W. Century Blvd. Suite 876 * Los Angeles, California 90045 * Copyright 2002, all rights reserved. * * This model is subject to change without notice. * Users may not directly or indirectly re-sell or * re-distribute this model. This model may not * be used, modified, or altered * without the consent of ON Semiconductor. * * For more information regarding modeling services, * model libraries and simulation products, please * call AEi Systems at (310) 863-8034, or contact * AEi by email: info@aeng.com. http://www.AENG.com * * Revision: 1.0 *========================================================== ********** .SUBCKT MC34063X swc swe ct 90 2 vdd isns drc * SW-col SW-em Ct gnd cinv vdd isns drive col *DC-DC controller * PSpice translation by Christophe Basso, christophe.basso@onsemi.com EB5 5 90 Value = { IF ( v(9,90)>2.5 & v(8,90)>2.5, 0, 5 ) } Q3 ct 22 vdd QN2907 V10 isns 22 DC=.3215 EB6 7 90 Value = { IF ( v(4,90)>2.5 & v(10,90)>2.5, 0, 5 ) } R3 5 10 100 R9 13 swe 100 C2 10 90 100p IC=5 R4 2 90 10MEG C10 2 90 50p R5 7 8 100 C3 8 90 100p IC=0 XTOF1 srst 90 ct 90 SWhyste params: VT=1.25 VH=.8 R1 srst vdd 10k Q2 drc 14 13 _Q3_mod EB4 6 90 Value = { IF ( v(2,90) > (v(vref,90) + v(voff,90)), 0, v(vdd,90) ) } GB2 vdd ct Value = { IF ( V(srst,90) > 3, 35U, -220U ) } EB3 9 90 Value = { IF ( v(diff,90) 3), 0, v(vdd,90) ) ) } EB7 16 90 Value = { IF ( V(vdd,90)-1.5 > 1.25, 1.25, IF ( V(vdd,90)-1.25 2.5, 10m, -10m ) } V4 voff 90 DC=2m C5 srst diff 10p EB1 4 90 Value = { IF ( (v(diff,90) > -1), v(vdd,90), 0 ) } R10 vdd isns 10k ** discrete models ** .MODEL QN2907 PNP BF=200 BR=6 CJC=19PF CJE=23PF IKF=100E-3 + IS=1.1E-12 ISE=1.3E-11 MJC=.2 MJE=1.25 NE=1.9 NF=1.21 RC=.6 + TF=5E-10 TR=34E-9 VAF=50 VJC=.5 VJE=.30 XTB=1.5 .MODEL DN4148 D BV=100V CJO=4PF IS=7E-09 M=.45 N=2 RS=.8 + TT=6E-09 VJ=.6V .MODEL _Q4_mod NPN BF=50 RC=.125 RE=.125 TF=10n .MODEL _Q3_mod NPN BF=50 .ENDS ********** * PSpice hysteresis switch made by Chris Basso .subckt SWhyste NodeMinus NodePlus Plus Minus PARAMS: RON=1 ROFF=1MEG VT=5 VH=2 S5 NodePlus NodeMinus 8 0 smoothSW EBcrtl 8 0 Value = { IF ( V(plus)-V(minus) > V(ref), 1, 0 ) } EBref ref1 0 Value = { IF ( V(8) > 0.5, {VT-VH}, {VT+VH} ) } Rdel ref1 ref 100 Cdel ref 0 100p IC={VT+VH} Rconv1 8 0 10Meg Rconv2 plus 0 10Meg Rconv3 minus 0 10Meg .model smoothSW VSWITCH (RON={RON} ROFF={ROFF} VON=1 VOFF=0) .ends SWhyste ***** Example models ***** .MODEL DN5819 D BV=5.33E+01 CJO=1.44E-10 EG=0.69 + IBV=6.00E-04 IS=1.65E-05 M=.671 N=1.41 RS=4.47E-02 + TT=7.20E-11 VJ=1.45 XTI=2 ***** .SUBCKT MC34063A 1 2 3 4 5 6 7 8 *BY KEHINDE OMOLAYO 2-20-03 *TERMINAL ID *SWITCH COLLECTOR=1 SWITCH EMITTER=2 TIMING CAPACITOR=3 GND=4 *COMPARATOR INVERTING INPUT=5 VCC=6 IPK SENSE=7 DRIVER COLLECTOR=8 * Translation by Chris Basso E1 10 0 5 4 1 R1 4 5 10MEG V1 20 0 PULSE 0 2 E2 11 0 3 4 1 EB1 13 0 Value = { 1M/(ABS((27.475-195M*V(12))+(36.002+244M*V(12))*V(9)- +(302.302+651M*V(12))*V(9)^2)+1F) } E3 12 0 6 4 1 E4 9 0 6 7 1 R2 6 7 10MEG EB2 14 0 Value = { 1M*((-10.765-151M*V(12))+(45.344+864M*V(12))*V(9)- +(35.99+1.378*V(12))*V(9)^2+(8.341+839M*V(12))*V(9)^3) } EB4 15 0 Value = { IF ( V(9)>0.32, V(14), V(13) ) } C1 19 0 10P EB5 16 0 Value = { IF ( V(20)1, 2, IF ( V(19)>1, 0, 2 ) ) ) } R3 16 17 150 C2 17 0 10P EB6 18 0 Value = { IF ( V(20)1, 0, IF ( V(11)1, 0, 2 ) ) ) ) } R4 18 19 150 D1 4 3 DMC34063 D2 3 6 DMC34063 C3 11 31 1N GB7 4 36 Value = { IF ( V(17)>1, -(224.4U+2.359U*V(12))*0.77, V(15)*0.77 ) } C5 23 0 10P EB9 21 0 Value = { IF ( V(20)1, 2, IF ( V(26)>1, 0, 2 ) ) ) } R5 27 26 150 C6 26 0 10P EB10 27 0 Value = { IF ( V(20)1, 0, IF ( V(10)1, 0, 2 ) ) ) ) } R6 21 23 150 EB12 33 0 Value = { IF ( V(11)>(1.148+184.6M*V(29)), 2, 0 ) } R13 33 24 10K C8 24 0 10P Q1 8 30 25 QSWITCH Q2 1 25 2 QSWITCH R15 25 2 100 D5 2 30 DMC34063 G1 2 30 26 23 5M R16 2 4 10MEG R23 31 28 1M V6 28 0 V7 36 3 EB13 29 0 Value = { I(V6)/(I(V7)+866.8M*I(V6)) } *** .MODEL DMC34063 D (CJO=2P N=0.05) .MODEL QSWITCH NPN BF=75 CJC=2P IS=3E-9 RB=1 RC=0.45 RE=0 + VJC=.75 VJE=.75 VJS=.75 *** .ENDS *********
MC34063X.asy (goes in the /lib/sym folder)
Version 4 SymbolType CELL LINE Normal -20 -128 -20 -112 LINE Normal 20 -128 20 -112 LINE Normal -8 -100 8 -100 RECTANGLE Normal -128 -128 128 128 ARC Normal -20 -124 4 -100 -20 -112 -8 -100 ARC Normal -4 -124 20 -100 8 -100 20 -112 WINDOW 0 0 -144 Center 0 WINDOW 3 0 144 Center 0 SYMATTR Value MC34063 SYMATTR Value2 MC34063 SYMATTR Prefix X SYMATTR Spicemodel MC34063.lib SYMATTR Description MC34063/NJM2360 1.5A Switching Regulator PIN 128 -96 RIGHT 8 PINATTR PinName SW_col PINATTR SpiceOrder 1 PIN -128 -96 LEFT 8 PINATTR PinName Drive_cnt PINATTR SpiceOrder 8 PIN -128 32 LEFT 8 PINATTR PinName Vdd PINATTR SpiceOrder 6 PIN -128 96 LEFT 8 PINATTR PinName Cinv PINATTR SpiceOrder 5 PIN 128 32 RIGHT 8 PINATTR PinName Ct PINATTR SpiceOrder 3 PIN 128 96 RIGHT 8 PINATTR PinName GND PINATTR SpiceOrder 4 PIN 128 -32 RIGHT 8 PINATTR PinName SW_em PINATTR SpiceOrder 2 PIN -128 -32 LEFT 8 PINATTR PinName Isense PINATTR SpiceOrder 7
