I am looking to understand what is the circuit inside a Ground Fault Current Indicator (GFCi). What does the circuit look like?
Simple google search is not yielding good results about the guts of it.
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityI am looking to understand what is the circuit inside a Ground Fault Current Indicator (GFCi). What does the circuit look like?
in principal, it can be a high ratio current transformer directly connected to a solenoid that breaks the circuit. Especially in early designs, electronics are often avoided and simplified in circuit interrupting devices. They are designed in as many ways as possible to fail safe, and this is part of the reason a mechanical switch is used.
This is another in depth teardown of a european design.
If you're going to try to build or design a GFCI circuit from scratch for your own interest or education, fine, it's a very interesting device. On the other hand if you want a device on which human safety will depend, buy one that is appropriately rated and certified in the region you live.
