Does anybody know what kind of connectors these are?
  • The size of the holes on the right picture is about 5 mm
  • The inner size of the holes on the left picture is about 3 mm
    \$\begingroup\$ It uses crimpable male and female inserts if that helps narrow things down. \$\endgroup\$
    Aug 4, 2018 at 17:08
  • \$\begingroup\$ @Andyaka Thanks ... I doubt I can ever use them, but I'm curious (and always good to learn). \$\endgroup\$ Aug 4, 2018 at 17:10
    \$\begingroup\$ What's the pitch? i.e. centre to centre of the holes. Is it the row spacing the same pitch? \$\endgroup\$ Aug 4, 2018 at 17:10
  • \$\begingroup\$ @TomCarpenter around 6mm (which fits with your answer). \$\endgroup\$ Aug 4, 2018 at 17:19
9
They appear to be Molex "MLX" power connectors (series 42021).
Molex MLX Connector Image
Here is the 6-way variant pictured above, part number 50-84-1065.
They are designed for 2.13mm pins, which fits the ~3mm hole measurement. They have a pitch of 6.35mm, which matches with the ~6mm measurement.
  • \$\begingroup\$ Confirmed that the pitch is around 6mm :-) ... thank you; I never saw these before. \$\endgroup\$ Aug 4, 2018 at 17:18
This connector series is also available in the old AMP line that is now supplied by TE connectivity. Their series is called the Universal MATE-N-LOCK.
(Picture source at Digikey Product Page)
In today's use of much lower power in most gadgets and devices these connectors are being used less and less. I still like to use them for power delivery because of their relative low cost and higher current carrying capacity per pin over other 2.54mm contact spacing connectors and headers.
  • \$\begingroup\$ Thanks for the clarification. Maybe I can use them in case I want to use multiple LED strips. \$\endgroup\$ Aug 4, 2018 at 17:51
