I have a question regarding VN5025AJ-E: High side driver IC.
Datasheet link - https://www.st.com/resource/en/datasheet/vn5025aj-e.pdf
In the figure you can see the application schematic. In the datasheet they have suggested to use a resistor at the ground pin for reverse battery protection (automotive circuits). I was just trying to analyze the path the current flows during normal operation and also during reverse battery condition.
Why are there two Zeners in parallel and also a resistor between the anodes of the Zener diodes? What will the output be under reverse battery?
