The Datasheet provies an example configuration for when the device is powered from the bus, and shows the bus Vss connected to UGND on the avr micro, but shows a connection to earth/ground on the other GND pins. Where is this ground coming from/connected to? The usb shield connection? Tied to bus' Vss?
Example configuration
It's the ground line on the USB cable, not the shield. The UGND and GND are connected together on the board. Here's an example of a schematic with Atmega32u4.
p.s. If you would like to learn more about connecting the USB shield on the slave device side, see this earlier question.
