I have this circuit.
I am trying to calculate the voltage between A and E by using Kirchhoff current law.
This is what I did.
First I wrote the equation for the left side, starting at A clockwise:
\$ -V_{B2} - I_{1}R_{3} + I_{2}R_{3} - I_{1}R_{5} + V_{1} - I_{1}R_{1} = 0 \$
plugging in the value and simplifying, I get:
\$ 17I_{1} - 10I_{2} = 8 \$
Now lets talk about I2. I assumed that this current was clockwise, so
\$ I_{2} = -2 A \$
right?
Plugging in this value on the first equation I get
\$ I_{1} = -0.705 A \$
Now I draw the 3 currents for the branches...
\$ i_1 \$ will be equal to \$ I_{1} = -0.705 A \$ \$ i_2 \$ will be equal to \$ I_{2} = -2 A \$
and
\$ i_3 = i_1 - i_2 = 1.294 A \$
so, \$ V_{AE} = 2 + 1.294 \times 10 = 14.94 V \$
I arrived at this value but B2 is killing me. I am not sure if I should add or subtract B2 to get \$ V_{AE} \$
is that correct?
Adding it as you did is correct. B2 has a voltage drop ( in the A -> E) direction. Equivalently, Ve + 10*1.294 + 2 = Va. Your numbers also check out in Spice
  • \$\begingroup\$ Thanks for the check. My brain was melting for a second. \$\endgroup\$ – SpaceDog Aug 6 '18 at 2:51
