I am trying to run WiFi router from a 12v lead acid ups battery. To get a stable 12v output from the battery I used LM2596. Problem is output is always 8.28v-8.50v. No matter how many times I spin the potentiometer out put is 8.28v. Is this a wrong approach to get stable 12v dc from a 12v lead acid battery?
LM2596 is a buck converter. It can only lower voltage. The parameter you are interested in is called "dropout voltage". To get stabilized 12V from an "approximate" 12V source you need a buck-boost converter.
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
