Does the diode ideality factor can be lesser than 1? or very close to 1?
ID and VD are the diode current and voltage, respectively
q is the charge on the electron
n is the ideality factor
k is Boltzmann’s constant
T is temperature in Kelvin
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityDoes the diode ideality factor can be lesser than 1? or very close to 1?
The ideality factor adjusts the original Shockley diode equation to fit non-Germanium diodes more closely. There's also a series resistance term.
Equation 3.13 from the original 1950 paper from Bell System Technical Journal:
The factor was added a few years later in a fascinating paper on radioactive p-n junction power sources.
With silicon diodes the ideality factor is closer to 2 than 1. It can be higher than 2. A diode-connected silicon transistor operated at reasonable currents has an ideality factor close to 1.
I don't think it is ever less than 1 for a real diode, but that may not be correct.
