HC-SR501 PIR sensor sends a continuous signal of 0-3.3V for the period of 4-8 seconds (depending upon the delay set).
Is there a way/IC I can convert this signal to a single pulse of 1 sec, preferably without using a micro-controller?
You can use a 555 Timer in the mono-stable mode which can give you 1 second pulse from your input of 4-8 seconds.
You can refer this datasheet for helping you construct the mono-stable multi-vibrator :
http://www.ti.com/lit/ds/symlink/lm555.pdf
