Why telephone lines use -48V not +48V? What’s the difference practically in -ve and +ve voltages? Detailed answer would be appreciated.
  • 4
    \$\begingroup\$ mathscinotes.com/wp-content/uploads/2016/04/positiveground.pdf \$\endgroup\$
    – G36
    Aug 7, 2018 at 14:30
    \$\begingroup\$ en.wikipedia.org/wiki/… It is an example of cathodic protection of the wires to make the most positive voltage inside the building to earth ground where the corrosion can be easily managed and the extensive -48V wire network protected. \$\endgroup\$ Aug 7, 2018 at 15:02
  • 5
    \$\begingroup\$ @Rumi. Why did you post this on Aviation.SE? Aircraft never used landline telephones! \$\endgroup\$
    – Transistor
    Aug 7, 2018 at 16:15
