I'm routing a large BGA SRAM that is connected to a BGA FPGA, and there's about 40 signals altogether connecting the two. I'm using Henry Ott's recommended 8-layer stackup:
1 ________________Mounting Pads/Low Freq. Signals
2 ________________Pwr.
3 ________________Gnd.
4 ________________High Freq. Signals (SRAM Layer 1)
5 ________________High Freq. Signals (SRAM Layer 2)
6 ________________Gnd.
7 ________________Pwr.
8 ________________Low Freq. Signals/Test Pads
I've fanned out the BGA such that all the SRAM pins are on layers 4 and 5. However, my routing results in a lot of parallel traces on adjacent layers, and I'm concerned about crosstalk: SRAM Layout screenshot (I'm in the process of length tuning. SRAM traces are different shades of blue, indicating address/data/control groups, not layers. Sorry for any confusion.)
Questions I have about SRAM routing:
  1. Should I revise my stackup to seperate these layers with a ground, or should I just try to avoid traces that are directly adjacent for long distances? Should I try to get all signals onto one layer using vias, or is that even worse?
  2. On a related note, when I'm calculating trace-impedence of signals on layers 4/5, is that calculated as a microstrip or an asymmetrical stripline? It's not open to the air, but it's also not sandwiched directly between two ground planes.
  3. Finally, this is unrelated, but for asynchronous SRAM do I need to length-match all signals or are there groups like in DRAM? I'm under the impression that for a write, for example, address and input data would need to arrive together, hence everything is length-matched.
This is my first high-speed design like this, and any advice would be greatly appreciated.
EDIT: SRAM part number for reference is CY62187EV30LL-55BAXI
  • \$\begingroup\$ What is the SRAM clock frequency? What is the spacing between the traces and the spacing to the ground plane? \$\endgroup\$
    – crj11
    Aug 7, 2018 at 18:13
  • \$\begingroup\$ The part number of the SRAM is CY62187EV30. Access time is 55ns. However, I'm considering swapping out for a faster, synchronous SRAM or pair of SRAMs. SRAM is chosen due to a high-radiation environment. My question is more conceptual really. I've been keeping minimum trace spacing at 10mil or so. 30 mil gap for length tuning squiggles. Layer spacing is 0.175mm to ground, and 0.13mm between 4/5. Dialectric is higher to ground though, at 4.29 vs 3.96. \$\endgroup\$
    – Toms42
    Aug 7, 2018 at 18:29
  • \$\begingroup\$ See edn.com/electronics-blogs/all-aboard-/4437717/… to get a ballpark idea \$\endgroup\$
    – crj11
    Aug 7, 2018 at 18:37
    \$\begingroup\$ Crosstalk should not be a problem if you have reasonable spacing for tracks on the same layer, and you don't have long stretches of identical traces on adjacent layers directly on top of one another. That is, do not accidentally create any large capacitances with your layout. \$\endgroup\$ Aug 7, 2018 at 18:54
Adding a ground layer between the two high speed routing layers will eliminate cross talk but obviously would add cost. Spacing the traces on adjacent layers by at least 3X (preferrably 5X) the dielectric height would reduce crosstalk. Adding vias always carries the risk of creating signal reflections and depends on the signal rise time and and how the vias are designed.
It is asymmetrical stripline. the reality is that it is sandwiched between ground planes. There are field solvers that can calculate the impednace of this geometry.
Length matching is a timing issue related to set up and hold of address and data lines to the write strobe. I don't really see a need here for length matching, but take into account skew between address, data and the write strobe. Depends on what speed you are running at.
