It seems that some, albeit not all, miniature circuit breakers have a minimum voltage rating under the IEC 60947-2 scheme (often 12VAC/DC). For instance, see the Sprecher/Schuh L8 series (PDF page 8) as compared to, say, a Schneider Electric Multi9 C60SP which has no documented minimum voltage rating under IEC 60947-2 (I'm using the C60SP here as it's UL1077/IEC, like the Sprecher/Schuh L8, but the C60BP UL489/IEC breaker lacks a minimum voltage rating as well.)
Why is this? Is this a limitation of testing, or of certain breaker designs compared to others, or of the external environs?
My interpretation is that there is no minimum voltage and thus not stated but like all contacts >2A there ought to be a minimum current for contact wetting or if non gold alloy plated.
The suitability for low voltage however is usually the over current ratio threshold for a rapid trip.
The Schneider specs of 5x breaker current are similar to the type B MCB’s in this regard as specified suitable for low voltage type PLC’s.
Being thermal-magnetic breakers they have a tighter tolerance for slow over-current from a thermal trigger and a wider over-current spec for more rapid magnetic response.
