I was given this power supply circuit, please see the image. The problem I'm having is when I connect the 10ohm load (solenoid valve), there is a large ripple when I scope the output. I have provided a few images to show you what I'm dealing with. I have tried adding different size caps in parallel with R23. Any help would be very much appreciated.
Image 1: The Power Supply circuit
Image 2: Power Supply Switching circuit
Image 3: Pulse without 10ohm load
Image 4: Pulse with 10ohm load
I have other images of the different caps used, 1nF and 0.1uF. Both of these in parallel with R23 made the ripple MUCH MUCH worse!!
Thank you all
